Who Makes a Good Portable Compressor
/ Who Makes a Good Portable Compressor #41
If I was running 500k thru a supply house I'd probably open one. But that's just me. I'm cheap. I got wholesale car dealers license so I could save sales tax.
when your wiring schools and hospitals, the $$$ move up super fast. you couldn't pay me enuf to open my own place hehe
/ Who Makes a Good Portable Compressor #42
for the small units the porter cable and dewalt have both been really reliable. In the small units oil-less is nice for convenience and ease of use. The larger units you have to be willing to drop some fair amounts of money to get a good compressor that is quiet. I saw a nice looking small-medium snap-on unit (6 gal) at a good price at costco. Just find out how many CFM your tools require, and that will narrow down the field a lot for selection. I avoid the box stores most of the time on these. I either buy used (estate sales and so on) or go to tool specialty shops. I just find Home Depot and such have a way to make their tools fail after 2 years. And I believe if you're getting a bigger it should be oiled, it's just too hard on the components under those loads without oil.
/ Who Makes a Good Portable Compressor #44
bought this one Portable Air Compressor - 2 HP, 8 Gallon, 125 PSI from HF for $99+tax 2 weeks ago.
A couple of years ago I bought the next one up. 2.5 hp (claimed!), 10 gallon, 125 psi max. Mine is red but I see they are black now.
I'm not impressed. I tried running a little HF die grinder continuous that specifies air consumption/pressure at 90% of this compressor's claimed output. High pressure didn't last long, soon it couldn't hold at 25 psi and the motor was smoking badly. Since then I've only used it for tires. Not Recommended, or at least discount HF's claimed output by 25%.
/ Who Makes a Good Portable Compressor #45
That unit is a slightly less than 1.5 HP based on both motor amperage and output. A true 2.5 HP unit would pull 25 amps and put out about 8 cfm at 90 psi.
The only real way to know horsepower is by amps. For reference, 15 amps @ 115V is 1.5 HP. Two HP is 20 amps, etc. And the breaker size should always be twice the amps of the motor to allow for startup inrush current.
/ Who Makes a Good Portable Compressor #46
All those horsepower ratings are bogus. Lowe's and HD always are at war with each other about the HP ratings on compressors and vacuum cleaners. If you do the math theres no way the units could match the written specs. they changed HP to PHP (peak horse power). I did a quick search of home depot and they show a $79.00 wet/dry vac thats 110 volts and 5 PHP.... ya right. 746 watts x 5 = 3,740 watts / 120 = 31 amps. hmmm, that should work on a residential 15 amp circuit ... no problem. So much for truth in advertising laws. They need to list the true HP ratings under load, not what it would ramp up to before it reaches speed.
At least my old 1-1/2HP Emglow is a real 1-1/2 HP motor......as you best have a true 20 amp circuit handy to use it.
/ Who Makes a Good Portable Compressor #47
California :
Thanks for "field report" :(
Like I stated only second item I've ever bought from "Harbor Fright" not a big fan of their stuff.
I have an older "Blue Emglo" for myself,and plan on giving HF to my 17 year old son to keep correct air pressure in his car tires,blow stuff off on occasion,and use a frameing nail gun with at home on projects.I was reading the HF reviews and your 10 gal got better reviews than our 8.I did not buy the extended warrantee,just has less than 90 days now.Thanks again for input.
If it last 3 years I'll be content. :confused:
Boone
/ Who Makes a Good Portable Compressor #48
Can't tell you how good it is I have not used it yet,but I bought this one Portable Air Compressor - 2 HP, 8 Gallon, 125 PSI
Only second item ever I have purchased from HF,the other was a cat#2 quick hitch attach.
Time will tell which HF list I put it on here on TBN,the crummy or the decent. :confused:
Boone
I've had that compressor for about 4 years now, and the pressure switch just went out on it. Worked good while it lasted, although it was very loud. I kept it in the garage to run the impact wrench when changing car tires and air up tires. My 60 gallon in the shop did the bulk of my work.
I think I may replace the 8 gallon HF with a little Porter Cable 150psi pancake compressor.
/ Who Makes a Good Portable Compressor #49
My little Makita MAC700 big bore 2hp is my "go to" compressor. It's the quietest and fastest recovering small compressor I've ever used. Did I mention how quiet it is? If your tools can run on 3.3cfm @ 90, you'd be well served with one of these at 52lbs and 80db. It's a bit heavier than comparison units, that's because of the cast iron. It's built to last.
Amazon.com: Makita MAC700 Big Bore 2.0 HP Air Compressor: Home Improvement
/ Who Makes a Good Portable Compressor #50
some are rated truthfuly, my new ch extreme duty 26 gallon compressor is a true rated 3 hp compressor. It draws 15 amps at 220v, and I run it on a 30 amp circuit.
/ Who Makes a Good Portable Compressor #51
I just looked at a couple of mine today...
The newest is the little Senco... it is 1/2 hp and states 4.5 amps.
My old Emglows have compressors made in Italy... 20+ years and no issues yet.
I took the plunge tonight and bought the Dewalt D55151. It was $218 w/ free shipping from Amazon.com. Should be here late next week. I'll let you know what I think after I use it.
/ Who Makes a Good Portable Compressor #53
The Makita MAC700 Big Bore 2.0 HP Air Compressor got great reviews on Amazon.
I just purchased one, and it has worked well with limited use so far.
- Spindifferent
I bought this stuff as well
/ Who Makes a Good Portable Compressor #54
What kind of compressor to get is a matter of what you need, and what you can afford. The best option is an all cast iron (not aluminum), oil lube compressor. For less money, you can get units up to about 2 true HP that run on 115 V (20 amp), and put out up to
6 cfm at 100-125 psi. For a little more, you can get a true 3 HP that runs on 230V, single phase, at 15 amps, that puts out 9-10 cfm at 125 psi. Non lube compressors are loud and don't last, but they are cheap. The question is, do you want a disposable unit, or one that will last for years.
Another Searz Veteran? I notice you use the term "true horsepower", so I thought I might enlighten some un-initiated folks here. In the "olden" days .. alot of searz/craftzmen stuff, would advertise electrical tools using locked rotor current to calculate horsepower .. including compressors. Sometimes .. using start current, which can easily be several multiples of running current. Amps times volts (watts) divided by 746.
James Watt invented "horsepower" to market his steam engines to replace mules and horses in mining operations. One horsepower, can lift 550 pounds one foot in one second. Wth the advent of electricity .. someone figured that to be 746 watts. Anyway .. using locked or startup motor current was a marketing ploy .. haven't had a searz catalog in mabe 25 years .. hope they have cleaned up their act :)
I have here, an old craftzman twin cylinder new in '76 as I recall .. cast iron .. 20 gallon tank .. came with 2hp .. put a twin capacitor 3hp on it mabe 20 years ago. It works .. never re-built .. gotta small leak .. but hardly ever use it anymore .. takes 220 ... solar off-grid here now. It was made by Campbell Hausfield. Certainly ... cast iron is the way to go for the bigger units.
A few years ago .. bought a Ridgid "portable" twin tank .. basically for nail guns .. very similar to the one offered at HD as a reconn Campbell Housfield .. which is oiless. It has become noticeable noisier over the last six years .. but mostly used for occassional tire inflation these days .. 3/4" impact wrench needs the big guy, and the 18v dewalt 1/2" impact has far exceeded my expectations and is truly "portable".
Cast Iron .. for the big guys .. Oil-less works fine, but as noted in this thread, tends to get noisier with time and use. To this day ... I Always consider advertised horsepower ratings to be suspect ... compressors ... bench planers .. you name it. Caveate Emptor as they say. A $20 Kilawatt from NewEgg or where-ever, can be most enlighting :)
/ Who Makes a Good Portable Compressor #55
Yep, they are still playing those games. The most you can hope to get out of a 15A 120V RMS outlet is right around 1.5HP. I recently saw something that advertised it was 120V 6HP! Talk about going nuts on the specs and blatant outright false advertising.
I'm thinking that spec was probably on a shop vac, and probably a cr@psman one at that.
/ Who Makes a Good Portable Compressor #56
I agree with the extreme over rating. I have an electric motor from the 1930s-1940s. My grandfather pulled it out of a building his company was working on. That thing is about 2x as big as a modern 3 hp motor, and even the shell of it is cast iron, weighs about 60#. Anyways that thing is rated at 1/2 hp, and my brand new general dust collector draws the exact same amperage, but is rated at 1hp. Now I know effiecency has improved, but I cant see it really making 2x the hp for the same amperage. Also, when wired for 220v, I am sure that old motor produces more useable power then that new 1 hp...
/ Who Makes a Good Portable Compressor #57
Being a roofer, I have had quite a few air compressors over the years. First one was a green campell husfeld from1972 That one lasted until 95
Bought an oiless black Coleman hotdog 4.5 gal that lasted until 2003
bought an emglo oil lube dewalt, and used it until 08 when the motor came loose, and needed one the same day, so bought a Ridgid pos-blows breakers even 20A
Fixed the dewalt,and use it as my backup. works well.
Got sick of blowing breakers all the time, so in September, I bought a Rol-Air gas wheelbarrow. Made about 70 miles from my house in WI. put an hour meter on the honda, I have just over 200 hours on it so far.
If you need bigger, I love my Ingersoll Rand 185 with a 3cyl Deere Diesel.
/ Who Makes a Good Portable Compressor #58
Has anyone ever used a large rotary compressor? One time at the flea market a couple of lowlife types were trying to sell the biggest 'portable' compressor I've ever seen. I think everyone who went by assumed these characters had just stolen it from the railroad or something.
This compressor looked like a rotary aircraft engine and sat on legs with the cylinders horizontal. (if it were a rotary airplane engine then the propeller would be on top.) Diameter was about 6?? ft and I think half the cylinders were gasoline engine cylinders, alternating with compressor cylinders. It started with a rope pull then spewed oil as it ran. I think it weighed around 250 lbs.
Anybody ever seen one of these? I can't find a photo online, but would love to see one.
/ Who Makes a Good Portable Compressor #59
Sounds like the engine off a Douglas DC-3.......
/ Who Makes a Good Portable Compressor #60
I can't afford to buy anything at Graingers.
Thinking of picking up a rolair compressor with wheels and it has to by relatively quiet.
I have a Senco 1010 that I love... so quiet but only good for a brad nailer... contacted Senco for sound ratings and have not received a reply.
My old Emglo has been bullet proof... it is a little heavy to lug around and loud.
Thinking about one of these with wheels...
https://www.rolair.com/products/air-compressors/hand-carry/vt25big
or this one that is a 1/3 lighter
https://www.rolair.com/products/air-compressors/hand-carry/vt20tb
Both say optimized for generator use in that low voltage down to 90 isn't a problem to start.
Also 5000 to 6000 rated life compared to some with 500 hour life or even one at 150 hours
2009 Infiniti FX35 AWD SUV (A64557)
2009 Infiniti FX35...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
Ditch Witch 6510 DD Trencher 4x4 (A62613)
Ditch Witch 6510...
