White Spots on Hood
/ White Spots on Hood #21
Glad to hear that this is a fairly simple fix. The third times the charm I guess.
/ White Spots on Hood #22
There's an oddity with Kohler Command engines and Synthetic oil.
Every manual I've read (Kohler or Cub) states that my engine can only use Synthetic up TO 40 deg F.
No, I don't understand it either
The manuals I read states, "Synthetic 5W-20 and 5W-30 is acceptable up to 4 degree "C" or (40 degrees F)." They then recommed 10W-30. Why they do not want 5W-30 used is anyones guess. Kohler also has the following in their owners manuals.
"Synthetic oils meeting the listed
classifications may be used with oil changes
performed at the recommended intervals.
However to allow piston rings to properly
seat, a new or rebuilt engine should be
operated for at least 50 hours using standard
petroleum based oil before switching to
synthetic oil."
It would appear Kohler does not want Synthetic Oil used in a new engine until after Fifty (50) hours.
/ White Spots on Hood #23
right, exactly what mine says.
Not sure why Kohler doesn't like Synthetic oil!
-Larry
synthetic oil."
/ White Spots on Hood #24
My first message was not quite clear.
This is a quote by ________(TractorLarry)There's an oddity with Kohler Command engines and Synthetic oil.
(End of QUOTE-TractorLarry)
Starrt of Quote by (Gator6x4)
This is what I said (Gator6x4) _________The manuals I read states, "Synthetic 5W-20 and 5W-30 is acceptable up to 4 degree "C" or (40 degrees F)." They then recommed 10W-30. Why they do not want 5W-30 used is anyones guess. Kohler also has the following in their owners manuals.
synthetic oil."
/ White Spots on Hood #25
As I read the manual, I see no allowance for Synthetic above 40deg at all.
The part about the 50 hour break in is a separate paragraph from the oil recommendations.
-Larry
synthetic oil."
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
