whinning oil pump
/ whinning oil pump #1
ealasimi
Have a L245 DT Kubota, I think the hydraulic oil pump is going bad. Starts to whine and then goes away. When it is making noise I can feel vibration on the tractor. Everything works fine and the noise comes for a few minutes and goes away. I am not really sure if it is the pump at all. Any ideas on what I should do or just wait until pump goes bad. Is there anything I could add to oil. Only operating the three point hitch.
/ whinning oil pump #2
Is it only whining when the 3pt is under load? if so.. it may be the relief valve you hear whining.
If it is whining before then.. invest in a hydro oil and filter change.. cheap insurance. Your oil may have water in it causing cavitation. Could also be sucking air on a suction line... and causing cavitation..
Soundguy
/ whinning oil pump #3
I agree with sound guy: whinning pumps usually cause of air or low fluid, water I have not seen/heard them whine but if the awter gets emulsified then it could help the air get trapped.
if it starts to growl well then feed it something. lol usually a new pump.
my best guess is same as his, filter and fluid change.
Mark M /forums/images/graemlins/confused.gif
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Caterpillar Service Magazines (A63117)
Caterpillar...
2016 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
iDrive TDS-2010H...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2021 John Deere HD35R Draper Head (A63111)
2021 John Deere...
