Which zero turn?
/ Which zero turn? #1
twes36
Tomball, Texas
John Deere
I will probably be opening up a can of worms.
I have 4 acres and have a SCUT with a belly mower for a lot of it, however the cut is not as even as I want for my yard and am looking for a zero turn for this . I have about an acre to cut for this and am looking to spend about $3,000 - what are the options out there?
/ Which zero turn? #3
I'm also in the market for a ZTR. So far I've found exactly nothing out there for $3K other than used. However, Kubota has a special going right now for a 36" for around $4K.
/ Which zero turn? #4
Similar recent thread.....
/ Which zero turn? #5
For $3K not much - at $3.5 to $4k the selections are much better. I like the Simplicity models - they are cousins of the Ferris commercial mowers, but almost any of the choices in this price range will be similar in features.
/ Which zero turn? #6
Highly doubt you will be able to find a decent new zero turn mower for $3,000.00
For 1 acre you should probably get at least a 60 inch deck.
Keep looking you might get lucky and find a nice used one cheap.
Sounds like maybe the belly mount mower you have is overdue for some good maintenance to make it cut better ?
/ Which zero turn? #7
Your budget is probably too low unless you go used. Under 3 grand they’re all pretty much the same. I paid $7k for mine and I expect it will out last me.
John Deere 6110M (A64126)
John Deere 6110M...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
