Which zero turn?
/ Which zero turn? #1
twes36
Tomball, Texas
John Deere
I will probably be opening up a can of worms.
I have 4 acres and have a SCUT with a belly mower for a lot of it, however the cut is not as even as I want for my yard and am looking for a zero turn for this . I have about an acre to cut for this and am looking to spend about $3,000 - what are the options out there?
/ Which zero turn? #3
I'm also in the market for a ZTR. So far I've found exactly nothing out there for $3K other than used. However, Kubota has a special going right now for a 36" for around $4K.
/ Which zero turn? #4
Similar recent thread.....
/ Which zero turn? #5
For $3K not much - at $3.5 to $4k the selections are much better. I like the Simplicity models - they are cousins of the Ferris commercial mowers, but almost any of the choices in this price range will be similar in features.
/ Which zero turn? #6
Highly doubt you will be able to find a decent new zero turn mower for $3,000.00
For 1 acre you should probably get at least a 60 inch deck.
Keep looking you might get lucky and find a nice used one cheap.
Sounds like maybe the belly mount mower you have is overdue for some good maintenance to make it cut better ?
/ Which zero turn? #7
Your budget is probably too low unless you go used. Under 3 grand they’re all pretty much the same. I paid $7k for mine and I expect it will out last me.
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
Cat CB24B (A60462)
Cat CB24B (A60462)
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2011 New Holland HT154 Rake (A63688)
2011 New Holland...
