Which Tooth For Toothbar
/ Which Tooth For Toothbar #1
GIJOE
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
I have been searching the forum for the last three hours and have not found the info I'm looking for. I have all the steal I need to build a toothbar except the teeth. Does anyone know what style tooth is used on the toothbars?
Thanks,
Joe
I know there are a bunch of places to buy them from, I need to know which series of shank to use.
Joe
/ Which Tooth For Toothbar #4
I ordered from Fabco, their catalog is online. I printed the page and kept blowing the teeth up on a copier until they wer full size. Then I compared them with my bucket and the steel I had for the toothbar and picked one. I already had the angle milled on the steel and ot was a bit off, but a few minutes with a 4" angle grinder in the 6 spots fixed that. Good luck, this is the best thing every for an FEL! Mine is on all summer.
moeh1,
Which ones did you end up going with?
Joe
/ Which Tooth For Toothbar #6
Joe,
Rats, I knew you'd ask, I don't recall....It was a few years ago and I probably don't have the paperwork anymore. Every bucket seems to be built different, I do recall that it wasn't the one I originally thought I would pick when I looked at the catalog online. Best I can recommend is to blow a few up and see what works for your bucket.
/ Which Tooth For Toothbar #7
I also used |Fabco teeth and adaptors!
Go online and the catalogue will have all the specs such as height, grip debth etc.
Basically you will be using a flat bar, say 3" X 3/8" to weld the adaptors onto and then you need to know your bucket metal thickness plus your existing cutting edge thickness to determine the type of adaptor you need.
Be a bit generous as I went too snug and needed to use a sledge to pound the adaptor bar into place.
On the otherhand the 5/16" 'ear bolts' have never failed in 3 years of usage.
But man what a differance in digging power.
Yep I can now scoop full buckets of rooty rocky top soil and fill stock.
Down side is back grading as with teeth that becomes a no-no, but then that is what a back blade is for, isn't it!
On the other hand with the bucket in 'full dump' and back grading mode you now hace a super 'root rake'!
Best thing since sliced bread! (for a loader bucket)
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
1952 John Deere A Tractor (A66408)
1952 John Deere A...
2013 BMW 7 series Passenger Car, VIN # WBAYE8C53DD133972 (A65563)
2013 BMW 7 series...
(26) Mineral Tubs (A66408)
(26) Mineral Tubs...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2016 Kubota RTV X1140 (A65579)
2016 Kubota RTV...
