which tire chains to get?
/ which tire chains to get? #1
johndeerezach
wellman iowa
john deere 3038e
i tried my new 3038 john deere out in the snow the other day and there was some loss of tractor with the r4 tires that i have and wanted to buy some chains. but what chains are the best outthere. the tires are loaded with steel weights.
/ which tire chains to get? #2
There are many that "are the best".
Might read up on the many, many threads discussing tire chains and try to sort through the variety of chains discussed.
Usually, the best are the ones the owner is using. Just the nature of the beast that we are most proud of what we have selected and are using.
I think any chain will be an improvement, and some work better on ice, some better on deep snow, and some are more comfortable on hard drive surfaces.
Wish you luck.
I assume you didn't lose your tractor, but lost traction :) ;) ;)
/ which tire chains to get? #3
The best chains are the ones that fit! I ordered a set (by size, mind you) and when I went to put them on, they were way too long. We're getting ready for a resizing day once we gather the right tools.
Joe
/ which tire chains to get? #4
Can you give a little more information? Things like do you plan on driving on pavement or cement, if so an aggressive chain could tear it up. Is your driveway steep? if so then a simple ladder chain may not be enough. Do you plan on going into the woods to do something like logging? If so then you'll want at least 3/8" thick chain.
Do you have a budget you have to stay under or are you willing to spend more now with the idea that a set of chains can last as long as your tractor so you might as well spend extra now and not wish you had a few years from now.
RING 2 STARTS HERE @ 9:15 AM (A62131)
RING 2 STARTS HERE...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
2022 All Aluminum Timpte 514 Trailer Electric Tilt (A63118)
2022 All Aluminum...
New/Unused Landhonor 8ft X 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2008 Freightliner B2 Bus, VIN # 4UZABRDJ98CZ17952 (A61165)
2008 Freightliner...
Polaris Ranger 400 H.O. (A61166)
Polaris Ranger 400...
