2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,593
Do people carve their initials in the outdoor park furniture you will be working on or is that something that only happens here in Tennessee?
They do have some carvings in them but we don't get overly exciting about it. Actually not all that many, but these tables have been out there well over 10 years, maybe 15 years.Do people carve their initials in the outdoor park furniture you will be working on or is that something that only happens here in Tennessee?
I am with the guys who recommended the random orbit sander. Start with perhaps 80 grit and move up to 150 grit for a swirl free sanding.We have some large picnic tables we care for which are located at remote locations. The finish is starting to peel so they need to be scraped, buffed and refinished. For cleaning and buffing them I thought I'd bring my generator so I could use my 4.5 angle grinder to do that job with. We'd then blow them off with air compressor when done. What pads might we use? I thought about trying these soft pads in 120 grit.
FPPO 5Pcs 4.5" x 7/8" Nylon Fiber Flap Disc Polishing Grinding Wheel,Scouring pad Buffing Wheel for Angle Grinder, Polishing Tools (Grit 120) View attachment 755689
Got it done with 60 grit 4x24 belts and it took about 6 of them. They'd get gummed up with tree sap. It did get treated with preservative/stain and will post pics when I can process them.
I have them, but didn't bring it into the field with us. This table is quite large and the surface in rough shape so i was happy with the life I got out of the belts.I forgot to mentioned there is sticks called ojffuue Abrasive Cleaning Stick made to clean sand paper it works really well and extend the life if sanding paper.
Hojffuue Abrasive Cleaning Stick Sanding Belt Band Drum Cleaner Sandpaper Cleaning Eraser for Belt Disc Sander Tool 35X35X105mm : Amazon.ca: Tools & Home Improvement
Hojffuue Abrasive Cleaning Stick Sanding Belt Band Drum Cleaner Sandpaper Cleaning Eraser for Belt Disc Sander Tool 35X35X105mm : Amazon.ca: Tools & Home Improvementwww.amazon.ca
ha k right on, lots of people don't know about this product so I figured I would mentioned it.I have them, but didn't bring it into the feild with us.
