Which rouch cut mower
/ Which rouch cut mower #1
Ed_C
Southwick, MA
I'm looking at tractors in the Kubota B7800/ L2800 and B7610 range. The 2800/ 7800 have 22 hp pto's. the 7610 has an 18 hp pto
All are ok with the other stuff I want to do with it, but I do have some light brush cutting on the edges of my property and som light field cutting in the middle. No overgrown hay fields and no 3 inch brush, but still more than a finish mower can handle
Any recomendations for a mower? The Frontier RC10's claim to be rated for 18 - 20 hp. Any others out there that can reasonably be operated at 18 - 22 pto hp?
thanks
/ Which rouch cut mower #2
I use a JD LX4 (48") brush hog on my 18.5 hp 4010. It'll cut stuff up to hood high. I use it with my FEL in place all the time; so, the weight is no problem.
Ralph
/ Which rouch cut mower #3
Ed C:
I had no problems with my old 48" Tebben economy model TC96-40 rotary cutter on my old Ford 1100 (13/11 HP) which if my memory serves me correctly :confused: required 15 PTO HP. The medium duty Tebben RC TC94-400 requires 15 PTO HP. Tebben rotary cutters are pretty popular with my local tractor dealerships. My avatar gives you an impression of what I cut in my lower field. Jay
/ Which rouch cut mower #4
general rule of thumb is 5hp per foot.
perhaps a bit less if its light cutting, perhaps a bit more in heavy brush.
rule of thumb also holds true for finish mowers as i can bog down my 30hp machine in the spring doing weekly lawn mowings with my 72" MMM deck
/ Which rouch cut mower #5
All I can add is a Land Pride 60" cutter has done quite well for me. See the pics and thread here.
Land Pride recommends 20 PTO HP minimum, but I ran this cutter (on the same field shown in the pics) behind a 16 PTO HP Deere a few years back. Worked well, too...
Thanks guys. Good to know that the tractor/ cutter combinations I'm looking at should do the job. Not looking to mow pastures, just keeping my edge clean and 2 smallish fields.
JBrumberg...WMass? Is that like Worcestor or all the way out where Sasquatch has been sighted (Southwick/Granville/ Tolland ;-) )
/ Which rouch cut mower #7
Ed C:
Some people think I am a "mini" Sasquatch or at least a "Hill Ape". I live north of you in Cummington :). Need any help send me a PM. Jay
/ Which rouch cut mower #8
Also consider the width of the cutter, I recommend getting one that covers the tractor's wheel width.
/ Which rouch cut mower #9
I agree :)- Jay
2019 DRAGON ESP 150BBL ALUMINUM (A67714)
2019 DRAGON ESP...
JOHN DEERE 325G SKIDSTEER (A67714)
JOHN DEERE 325G...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2014 Dodge Charger Sedan (A66738)
2014 Dodge Charger...
2011 SPM SAFETY IRON 100 BBL 10 PUMP MANIFOLD TRAILER (A67714)
2011 SPM SAFETY...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
