Which remotes do you use?
/ Which remotes do you use? #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Being that I'm hoping to get a grapple soon, I'll be using the remotes for the first time... Which set do you guys use? The green lever bounces back to center when I move it, the blue one seems to stay wherever you push it.... whats the difference?
Thanks in advance.
/ Which remotes do you use? #2
I used a divertor - check out my mods thread for some info on it.....
I thought both the blue and green were to act the same. Both spring centered standard remotes
/ Which remotes do you use? #3
Can one of these remotes be used by running 2 hydraulic lines to the front for a Telescopic Boom?
/ Which remotes do you use? #4
Absolutely. Many people do just that rather than spend the money on a diverter, or 3rd function kit. I'm planning to get a grapple, and I'm still undecided which way to go, but running a set of lines from a rear remote is definitely the least expensive. A third function kit is probably the best, but starts to get a little pricey.... but what doesn't these days?
/ Which remotes do you use? #5
Thats good info on the rear remotes. What would one ask for when ordering the fittings for those rear remotes?
/ Which remotes do you use? #6
Yes, exactly what I was wondering. What are the ends called? I could not find it in the manual.
/ Which remotes do you use? #7
I took pictures with my phone of the rear remotes with a tape measure held across the opening. Showed it to the guy in the hydraulic shop and he went a grapped the correct male fittings for me.
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
Skid Steer Pile Hammer (A65640)
Skid Steer Pile...
PATRIOT 5100 ELECTRIC CAKE FEEDER (A64277)
PATRIOT 5100...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2023 Case 75c FarmAll Tractor (A62679)
2023 Case 75c...
