Which remotes do you use?
/ Which remotes do you use? #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
Being that I'm hoping to get a grapple soon, I'll be using the remotes for the first time... Which set do you guys use? The green lever bounces back to center when I move it, the blue one seems to stay wherever you push it.... whats the difference?
Thanks in advance.
/ Which remotes do you use? #2
I used a divertor - check out my mods thread for some info on it.....
I thought both the blue and green were to act the same. Both spring centered standard remotes
/ Which remotes do you use? #3
Can one of these remotes be used by running 2 hydraulic lines to the front for a Telescopic Boom?
/ Which remotes do you use? #4
Absolutely. Many people do just that rather than spend the money on a diverter, or 3rd function kit. I'm planning to get a grapple, and I'm still undecided which way to go, but running a set of lines from a rear remote is definitely the least expensive. A third function kit is probably the best, but starts to get a little pricey.... but what doesn't these days?
/ Which remotes do you use? #5
Thats good info on the rear remotes. What would one ask for when ordering the fittings for those rear remotes?
/ Which remotes do you use? #6
Yes, exactly what I was wondering. What are the ends called? I could not find it in the manual.
/ Which remotes do you use? #7
I took pictures with my phone of the rear remotes with a tape measure held across the opening. Showed it to the guy in the hydraulic shop and he went a grapped the correct male fittings for me.
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
43023 (A59228)
43023 (A59228)
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
iDrive TDS-2010H...
2007 PETERBILT 386 T/A 6X4 SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 386...
