which portable generators do people have
/ which portable generators do people have #41
same here.. the EU2000 - I actually have 2 of them
one will run a fridge OR a deep freezer OR a 5/6k room window AC.. on a fuel tank of fuel (about 1 gal) it will run about 7 hrs..
the other we use to power the necessities -TV, satellite dish, internet router, phone chargers - the REAL important stuff
Recently i converted both to run off propane - US Carb was running a special last year for about 50% off - and they came up with a design that you dont need to 'drill' the carb anymore.. You get less run time from propane - BUT at ~4.7 gal per 20# tank - it should run at least 25 hrs or more on a tank..
we are on a well and electric water heater - so i have thought of trying to find a used PTO generator that could be used to heat water, then switch over and run the well pump while we showered
Brian
Even a small PTO generator should run the water heater and well pump just fine. A huge energy guzzling water heater pulls 4600 watts, and a huge deep well pump won't pull more than 6000. Call it 12 kw absolute worst case, and probably a lot less than that.
/ which portable generators do people have #42
Contrast that to my mild climate and a house outfitted with fine 19th century technology. Electricity is a convenience, not a necessity. We can cook on the wood stove, or heat water for a bath. We can go a couple weeks without doing laundry, and gravity feed water will last almost a month. When I used a gas powered generator, I wouldn't even bother to get it out of the barn until the second day of a power outage. I often used a little 1000w camp generator to run the fridge and freezer or the satellite dish.
Same here. 1830s-vintage farmhouse. Gravity-fed well (not city-water pressure, but probably 35psi...enough for a shower), propane stove & hot water, woodstove for heat. I did pick up a 4000W Champion generator a few years ago mostly to keep the refrigerator & freezer cold (figure on running it for an hour or so 3x/day). Good insurance...haven't lost power for more than a couple hours since I got it. :D
/ which portable generators do people have #43
That's the problem. You have to run the darned things or they quit working. You have to know how to flash the coils or exercise them periodically. Then you are stuck with gasoline in the tank. There's nothing like finally getting the generator running, only to find there is no electricity coming out of the generator. A 12v battery will flash self-excited generator coils, but it's not the sort of thing you want to deal with in a blizzard. That's why I went to a propane unit. Turn the tank on, hit the electric start, run a couple space heaters for 20 minutes and shut it down. The directions say run it under full load, but I figure 15 amps on each leg is good enough for a 6 kw genset.
I bought my 4400/3600 w gasoline powered generator about 1997, from Harbor Freight on closeout, for $279 including free shipping. That was before the Y2K panic that inflated generator prices. About 2002 we had a 5 day outage and it served well. My wife had the flu, and was really pleased that she could take a hot shower. In 2006 it provided power for an addition on my barn. It has maybe 50 hours on it total. I should sell it, because it's just taking up space in the barn. The big problem with gensets is how reliable power is. If you had outages every year it would be a regular thing to maintain them. If they sit in the barn for 10 years, it might take some tinkering to get them working.
Thanks for all the replies ! Some of you really have nice whole house units. The welder/generators are great as well. So far the Champion dual fuel at Costco is what i think serves us best. Portable...which allows me to take it anywhere on the property. That way i don't have to bring things back to the shop for welding if needed. Like the idea of having propane as a backup since we live in a somewhat remote area with propane service. We also have a rv that has a Onan 7500 watt generator for added supply, it runs off diesel. Now to get a electrician out to wire a receptacle at the water pump well so i can plug it in to either generator.
Thanks again everyone
/ which portable generators do people have #45
Exactly how do you flash the coils?
/ which portable generators do people have #47
I don't have any real pressing NEED for a generator, but for years I've thought a $1K Honda EU2000i would be handy to have around.
I recently noticed the new $1K Honda EG2800i. I'd been thinking about it, then I saw a video of something similar mounted on the front of a tractor (instead of weights). That pushed me over the edge and I decided to order it.
Hadn't gotten around to the actual ordering when I noticed this A-iPower SC2000i at Costco for $499. Only 2 of them left, so I decided to grab one.
I haven't opened it yet. Still kind of deciding whether I want to keep it.
Right now I envision tossing it in the back of the RTV500 when I'm headed down to the sheds about 1/4 mile away. I'd use it to run a vacuum, or electric impact, or leaf blower.
I'm pretty invested in the Dewalt cordless ecosystem, so something like the $250 DEWALT DCB1800B Portable Power Station might actually make more sense for me.
/ which portable generators do people have #48
These are nice generators, but for a home, it is really nice to have 220 volts, especially with a well pump.
Right, the well pump is my biggest concern while on the generator. I have a 7000W Gillette with a Honda GX engine. 6%THD. I have not seen mention of THD but if you are powering some electronics you want as low of number as possible. To allow more amperage for the pump I try to have most everything off other than necessities. ie the wife can't use a hair dryer. No toaster, no microwave that type of thing. Big things like clothes dryer and heat pump are not on the generator.
/ which portable generators do people have #49
Simplicity itself. Self-excited coils rely on induced voltage to generate a magnetic field. Over time the residual magnetic field will decay to the point that it will no longer generate enough current to excite the coils. All you have to do is plug in to both legs of the generator and hook the plug to a 12v. battery. All it takes is a couple of seconds. The hassle is finding a plug, wiring a pigtail onto it, and clamping jumper cables to the pigtail, in a blizzard, in the dark. Piecea cake.
That's why the generator instructions tell you to run the generator under load every 3 months. That's overkill, but nobody knows how much. Vibration will speed up the decay of a residual magnetic field.
There are other reasons a generator might not make electricity. Reset the breakers before you do anything. Check the brushes. Look for dauber nests on the armature. :D If you have a bug infestation, you may have to take the whole thing apart and clean it.
/ which portable generators do people have #50
/ which portable generators do people have #52
I bought a 3.5 Kw generator from Princess Auto going on to three decades ago I've yet to use it and I haven't even put gas in it. 8 hp B&S engine on it. It was dirt cheap at the time (slight damage to the frame around it) but by the time I had heard about a generator losing it's ability to generate if left sitting too long, it was already too long! I knew it had to be reflashed but since I didn't have one of these it never got done!
/ which portable generators do people have #53
Wow... as soon as I buy any tool I scramble to use as fast as I can get it running!
/ which portable generators do people have #54
Honda EU3000is. I have two of them. Very reliable and quiet. I used one to provide electric for AC in my camper on the farm all summer. Change the oil as per the schedule and they do very well.
/ which portable generators do people have #55
You might consider a portable welder if you have need of one.
I keep a Lincoln 305 G in my garage for power outages. It does require pulling it out the door with the pallet jack, though.
Terry
/ which portable generators do people have #56
Generac 4000EXL. Bought just before the great Y2K panic. Still starts easy and works good.
/ which portable generators do people have #57
Terry
NICE Garage !! Wow !
/ which portable generators do people have #58
Shopping for a portable generator. Don't want to power whole house, just some basic necessities. I see where they make a dual fuel ( gas or propane ) generator. Since we have propane for heat there will always be a supply at the house. I was thinking the size range at between 5000 to 8000 would be sufficient. We have 24 acres so i will be using it also to go out on the property for projects.
Chuck H
I just purchased a Harbor Freight Predator 8750/7000 13hp gas generator, for $529.00 with the wheel kit.
I have to say it appears to be a 9 out 10 in quality, fit and finish. It has a cast iron Honda clone engine.
First thing I did was install an hour meter,($12.00} replaced the OEM sparkplug with a NGK plug and added oil (Rotella 15w/30W). It started on the second pull. I've since bought the HF battery with a 25% coupon and no core charge. I purchased two extra plugs an air filters on ebay.
Very important, I ran it 3 hours at no load for proper break in. At 20 hours, I will change the oil to a full synthetic.
I plugged in a Killawatt meter($18) during break in and it showed very clean Watts, volts and kHz!
My initial impression is that it a great value, very quite as compared to previous units and provides clean power.
/ which portable generators do people have #59
They really hit a home run with their Predator engine lineup.
/ which portable generators do people have #60
i have the same generator, im curious as to why you think a no load break in is the right way to go?
also thats a pretty thick oil for a splash lube in the winter no? i use 5w-30
and according to HF the THD on this generator is <25% which is not considered clean although i did scope it and it looks very good
one thing i ran into though, was the governor spring can/will osculate when coming from a high load to an idle or vice vs. i ended up adding a piece of 1/2 pipe foam insulation over the spring to stop it from osculating. that made it much more stable for me
i hope u change the oil before 20 hours, alot of metal in it after only 1 hour of breakin, ( i do a varying load break in) so mine may have had more metal in it
