which portable generators do people have
/ which portable generators do people have #1
747driver
Tellico Plains,TN
Kioti CK27 HST
Shopping for a portable generator. Don't want to power whole house, just some basic necessities. I see where they make a dual fuel ( gas or propane ) generator. Since we have propane for heat there will always be a supply at the house. I was thinking the size range at between 5000 to 8000 would be sufficient. We have 24 acres so i will be using it also to go out on the property for projects.
Thanks
Chuck H
/ which portable generators do people have #2
I bought a Coleman 8000 about 15 years ago and still use it today. I did power the house with it for years but have since gone to a whole house Generac. I made a sling for the Coleman and move it around the property with the tractor.
That said, there are many more choices today. Big box stores, Harbor Freight, Northern Tool all have good units. It is my opinion that it is not necessary to buy a big name brand if you just want an occasional use generator.
/ which portable generators do people have #3
I have the Champion dual fuel 8000 running watt generator bought from costco.
Its heavy but has wheels and a handle to move. My entire house runs off propane so I always have a supply as well.
I had a big transfer switch wired in so the generator will run entire house if needed.
Its a great unit, and will run for 8 hours at 50% load on a tank of gas, and 5 hours at same load on a standard grill sized bottle of propane.
They are like $750 at costco
/ which portable generators do people have #4
/ which portable generators do people have #5
I bought a Briggs & Stratton 30664 - 8000 Watt Electric Start Portable Generator a couple years ago; it will run my entire house. Last time the power went out, I ran it for 40 hrs straight with out any issues. Don't buy a Duromax, had to return 2 of them before I bought the B&S.
/ which portable generators do people have #6
I'd be inclined to go with the Champion from Costco. Champion has a good reputation for parts availability and quality and Costco has the unbeatable, return it is you ever are unsatisfied policy. If money is no object, get a big Honda.
/ which portable generators do people have #7
I have a 10kw from Miller, a Bobcat 250. I use it for arc welding mostly, but also power my Mig in the field. In a pinch, it can run my whole house. A bit thirsty on gas, but I can handle that easier than another machine.
/ which portable generators do people have #8
My "portable" genset is a Honda inverter, we LOVE the thing!
SR
/ which portable generators do people have #9
I have a Lifan 4k 110v inverter, love how quiet and efficient it is. My FIL has a duel fuel Champion in similar size. So loud but starts easily, no crappy gas issues.
/ which portable generators do people have #10
I have a 6500 W Coleman, and it is great for emergency power, but it is LOUD. I would love to have a 2000w Generator/Inverter (Wen, Black & Becker, Westinghouse), or better yet two of those connected in parallel. They are quiet. Honda or Yamaha would be even better, but much more expensive.
/ which portable generators do people have #11
i also have a Miller Bobcat 250 mounted on a small trailer. I have run my whole house on it for a few days after a storm, plus use it to power other tools occasionally. Even use it to run my Mig when I want to use wire feed. I also have a Honda 2000. I love it when portability is important and its super quiet.
Sent from my iPad using TractorByNet
/ which portable generators do people have #12
I have a Champion dual fuel, 7000 watt continuous on gasoline. For the camper, we use 2 Honda EU2000 inverters running in parallel. Love the Hondas, can barely hear them, and for simple tasks I usually grab just one of the Hondas. Weighs less than 50 pounds and provides 2000 watts peak.
I've run the entire house with the Champion quite easily (just have to be smart with the load). Since you already have propane, I think a dual fuel unit is the smart choice. Just bear in mind that your output will be less running propane - the Champion loses around 700 watts on propane. 6300 watts is still plenty for running the basics.
Just my 2 cents....
/ which portable generators do people have #13
5500 watt ( 8500 starting watts) Briggs and Stratton.
Nice unit.
/ which portable generators do people have #14
Kubota of course. :laughing:
I've used these for years (like 20+) on the const. sites.
/ which portable generators do people have #15
Same here.....mine is an older unit, 8,000watt on the electrical output side. I figured a 'two-fer'.....a welding unit along with a generator was a better way to go.
Plus I figured I'd use it enough being both that when I DID need a generator, it wouldn't have sat around for couple years and the carb be all varnished up to the point it wouldn't run.
/ which portable generators do people have #16
I have a Sportsman 7000LP that I bought from Home Depot for $599. I picked up a 100 lb. cylinder from Lowes for $79, had it flushed and filled, and plug in a couple space heaters for the quarterly maint. run. Docs say it will run 8 hours on a 20 lb. tank at half load. I keep the battery on a good quality tender. Key start is a snap, and there are no fuel storage problems. I have about 80 lbs. of other propane tanks around. It's very quiet and convenient, and big enough to run the well pump and water heater at the same time. The longest power outage we have had here was 5 days about 15 years ago, so I'm good for fuel. The propane will still be good 15 years from now. It is very quiet running. That's the up side.
The down side is that it uses brushes, so the power has a lot of high frequency noise, and the brushes will wear out. I ordered a spare set of brushes, in case I have to change them. At current usage rates I might be 90 years old and unable to remember where I stored them when they need replacing. Oh well. I wired a .02 MFD cap across each of the transfer switch lugs to ground, which should soak up a lot of the RF noise.
Regional data: Summer outages are unheard of. No tropical storms here, and if I need a fire pump I have a 5 hp Honda plumbed to a 2500 gallon cistern, which also provides low head domestic water in a power outage. We have wood heat, and the comfort level of the house doesn't change during winter outages. We just cook on the wood stove. If I was on the Gulf, a genset that would run the AC would be a must.
/ which portable generators do people have #17
Thanks
Chuck H
I bought a Champion 3750/4100 Lp generator at tractor supply for $279. It sat for about 2 yrs until we just had a power failure for 38 hrs. I dug it out of the shop, hooked up the 20# bottle from the grill and it fired on the second pull. I never got around to setting up a connection into the house, so I pulled about 250 ft of extension cords to the freezer, refer, some lights, and a fish tank. I could not believe how long it ran on one tank-- 17 hours running the aforementioned. Still had plenty of juice to supply, it was barely running above it's high idle. I have had 4-5k generators before and this champion was probably half the noise level. I would probably go with a dual fuel model.
/ which portable generators do people have #18
I have a winch 10k pto. Tractor always is running, have 1100 gal of fuel in basement and don't have propane. Gas, well that is so problematic with the ethanol crap, I would never go that direction.
/ which portable generators do people have #20
SR
These are nice generators, but for a home, it is really nice to have 220 volts, especially with a well pump.
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
(2) New 26X9-14.5 severe duty batwing tires on 5-lug batwing rims, Coal Valley, IL (A65640)
(2) New 26X9-14.5...
2012 Ford F-550 Flatbed Truck, VIN # 1FDUF5GY6CEB41814 (A65563)
2012 Ford F-550...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
