which portable generators do people have
/ which portable generators do people have #461
When I installed my genny panel, I don't remember EVER seeing a breaker interlock, which would have been the way I went due to cost, but I stumbled across a 6-circuit genny panel for really really cheap, so went there.
I'm getting ready to put a genny system on my country property, and by all means it's getting a breaker interlock system on the mains panel instead, I really like that method.
As for that 'undersized' generator some use, if you only have a power outage once in a blue moon, does it make sense to keep a large investment heavy duty unit sitting idle to protect pipes and frozen food, or get one that can run minimal load when forced to. If it's run hard and it's life span is shortened by even as much as 75%, it's still likely to have hundreds of hours more life expectancy than it will EVER be needed. Best insurance money I ever spent was the first genny I bought, we got it because the house where it's at was getting hit w/ power outages weekly for a few hours at a stint due to upstream construction backhoe fade, bought the genny and installed the panel, and have in the past 18 years now had ONE power outage that caused us to drag it out - otherwise it gets religiously run about every 4 months but only to maintenance run it.
/ which portable generators do people have #462
That's not what a large unit is for. Cold is a nuisance; heat is a killer. The 1995 Chicago heat wave killed 739 people, and the 2003 European heat wave killed 70,000 people. A heat wave is the big stress on a power system and outages are most likely when wires heat, sag and short out. I heard plenty of horror stories about living without AC after Katrina. Heat + humidity = misery. A 1 kw generator is fine for me to keep the freezer cold and run a TV and the satellite dish for at most 4 hours a day. I never criticize someone who wants a full house generator 24/7. Maybe they need it. I don't live there. It's their climate and their money.
/ which portable generators do people have #463
I have i fully automatic system because i want house protected from freezing if im away. This week its expected to get to -4f. Cheap insurance against busted water pipes or frozen horse waterers.
Mind you i install these units so it wasnt too expensive, but either way i love the unit. Have had 3 outages in past 3 months. Nearing 20 hours on generator at night in cold.
/ which portable generators do people have #464
In 20 years in Boston, we have been without power for a total of two hours.
But after Hurricane Sandy hit the mid Atlantic coastal states, we researched what worked and what did not. Most folks who had generators ran out of fuel in a few days, and even if they had enough gas cans, had to drive 40+ miles for more gas - if their car had not been flooded by salt water. We live in an area that probably will not be flooded (388 years and counting!), but might be an island 12 hours a day when the tide is up.
Normal tidal swing in Boston harbor is about 10 feet and we had a super moon high tide earlier in the winter of 13 feet. Some of the areas in NY were 8-14 feet above normal.
So we set a plan to be able to survive over a week without power, in winter. That necessitated using the smallest possible inverter generators. They are portable so we can also loan them to relatives, and my nephew used one of the EU2000 to keep his house heated, phone charged and a few lights for four days earlier in the winter.
/ which portable generators do people have #465
So we set a plan to be able to survive over a week without power, in winter. That necessitated using the smallest possible inverter generators. They豎*e portable so we can also loan them to relatives, and my nephew used one of the EU2000逞エ to keep his house heated, phone charged and a fewlights for four days earlier in the winter.
Kinda where I am at... with a gas 3kW gen, and 250gal of propane for heat, we feel we can live comfortably for two weeks easily (including other provisions) whenever it may hit. Minimally probably longer. If I procured a larger gen to power the well, then we are business for the long haul. Thanks to my wife's victory garden. :salute:
/ which portable generators do people have #466
That raises an interesting question, should I convert my Northstar 10,000 to propane for reliability or not? Currently gasoline, and has worked extremely well since purchased for Y2K.......red face.... embarrassment....
Been trying to rid our home of 220volt appliances, first to go was 50 gal hot water tank to a Rinnai 98i on demand, been working flawlessly so far and it's 110 volts. Can't change deep well, but clothes dryer is next on our list, or convert to propane? Probably should just buy propane unit so as to not explode our home. Earlier home in Greenwich we buried a 1000 gal tank, here, back in Salem we installed an above ground 1000. On both, thought was, one fill up in August takes care of whole year, that's what I like $ .85 gal propane. Should explain, member of Galway CO-OP the largest energy CO-OP in the nation with 8000 members and counting. This is fantastic to have this capacity in all, but I being gone at work week at a time, this switch over falls on Deb's shoulders. She's not a real fan of switching box over, flipping breakers, starting unit, while maintaining system during power failures. She has been showing me Generacs
"On Sale" so I can see where this is going.. mo money...
I would probably track down propane conversion for the Briggs twin V 16 hp. Originally, I was looking for generator panel with elaborate switching, went to Hill Electric in Glen's Falls, Mike showed me a Murry panel box that did the very same thing, disconnected grid and energized auxillary power lines from barn. Just a $3.00 metal bracket fits over transfer main breakers to gen panel, works fantastic for $60 instead of $500. At that time added exhaust pipe to Northstar thru the wall of barn, now, barn is being removed so gen is just in door way ready for use. A little less convenient but gets the job done in a pinch.
/ which portable generators do people have #467
FWIW one of the problems people had during the extended Hurricane Sandy outage was drying clothes. Our dryer and heat is gas, so we can wash and dry clothes even with the little Hondas, I think. Along with 240V we gt the B&S Q6500 to be sure we could run a window unit and sthen me other items.
/ which portable generators do people have #468
You know, a piece of rope and some cloths pins works pretty good!! Even if it has to be in a garage or out building...
My wife prefers to hang cloths out to dry, even though we do have a dryer...
SR
/ which portable generators do people have #469
SR
I have used the garage in the pinch and then finished them off hanging in the living room at my previous house. The wife says I can not put up a clothes line at this house but what does she know? I just haven’t figured the best location yet.
/ which portable generators do people have #470
I always believed a 500 gallon propane tank was good insurance and it had been for decades before the bear population exploded.
Bears are now notorious for breaking off regulators and lines... I lost the contents of a recently filled tank due to bears... the bear came back but I had the supply on the tank turned off.
Found out it is now a common occurrence....
Just another thing to think about... glad no one was smoking are static electricity or lightening strike with all that gas escaping and no one home.
/ which portable generators do people have #472
Came as a surprise to me...50 years and no problems.
The bears enjoy a protected status and have free reign... kids out riding bicycles and trikes say Mommy the bear is coming... in broad daylight with no fear.
I have had ship lap siding ripped off the cabin... there is no food or warmth as the cabin was winterized... bears just looking to make a den is how it was described by animal control.
The most logical explanation is just bears being bears... they are very powerful and the claws quite capable.
Residents are required to purchase bear proof containers for trash service and it is ill advised to leave anything inside your car... even a pack of chewing gum or certain air fresheners...
The local agency advises electrifying the perimeter for problem bears... not sure how good an idea that is to do around a propane tank?
Viral video from south Lake Tahoe reminds residents to be bear aware - YouTube
Bears in Lake Tahoe - YouTube
I can see a future ordinance requiring tanks to be underground in light of the bear damage.
/ which portable generators do people have #473
That surprises me. A bear tag is $10 in Oregon, and they hand them out free with the hunters pack. If you shoot a nuisance bear out of season you just have to call fish & wildlife and give them the carcass. The do-gooders banned hound hunting and baiting years ago, and the bears have become quite a nuisance. I see bear sign on my place every year.
/ which portable generators do people have #474
Something like 30,000+ bears now on the California side...
I had a long talk with authorities saying a bear tearing off the siding of my home had better hope I am not home...
To say it didn't go well was an understatement... I was told harming a bear is a serious offense and more so since I have not mitigated the risk by fortifying my home similar to a Concentration Camp Electric Wire... people actually are stringing hot wire across doors that they have to removed every time they use the door...
/ which portable generators do people have #475
/ which portable generators do people have #476
Why do bears mess with propane tanks, of all things?
probably the same reason that cows with horns will use them to pull distribuitor caps and wires off tractors randomly...
/ which portable generators do people have #477
SR
Haven't you heard Rob ? Today's generation is Green ! ;)
Cracks me up....... in some/many respects my grandparents and parents generation were much more green....
Rgds, D.
/ which portable generators do people have #478
Rgds, D.
That's true...I have one neighbor who has NEVER had a cloths dryer... Another that has NEVER hung cloths outside...
Guess what one moved here from town? lol
SR
/ which portable generators do people have #479
Livestock and other large animals love to rub against things. I remember my normally mild-mannered uncle getting seriously irritated when I was a young lad - I was visiting the farm, and as usual, I was wandering the barns and equipment sheds. The one bay on the equipment shed they had left open-fronted had a small-square baler parked in it that day. Turns out one of the cows had wandered in next to the baler and started rubbing hard enough to knock the baler-counter dial off. Uncle was not impressed..... a cattle resistant self-closing gate was on that bay soon enough.....
Many animals like to rub against things that don't easily move..... something to keep in mind with any outside-stored equipment.
Rgds, D.
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
