which portable generators do people have
/ which portable generators do people have #421
My well has a cistern so it has the well pump plus a booster pump. So I have to be careful with the gen power in case both run. Also on power up if both are calling to run. Then the inrush of each pump adds for a total. My outages are short so I shut the well off when the commercial power goes out unless it gets too bad.
Similar to my system. I set the bottom of the 2500 gallon cistern about level with the window sills in the house, so I have gravity flow water with no electricity at all. It's nice for flushing the toilet. In a real emergency, I could heat a copper laundry tub of water on the wood stove and mix it with cold in the bathtub for a bath. The longest outage we have had was 5 days about 15 years ago, so the cheapie Harbor Freight 5000/4400 that I paid $279 for has served well for years. I recently bought a 7000/6000 electric start lpg unit because hauling a 150 lb. generator out of the barn when I am 80 won't be any fun. The old generator still provides occasional power at the barn, which is about 200 yards from the house.
/ which portable generators do people have #422
larry this is what i did
https://i.imgur.com/tqTPZyH.png
it has a tow bar on it as well, i can pull it with the atv 0 issue.
/ which portable generators do people have #423
I was at HF today, a lady was returning a 8750 watt Predator gen set. They tried to give her a new one and she said NO WAY shaking her head fast!
When she left I asked the manager, "is that generator dead?"
The manager said, "yes, she powered something she wasn't suppose to"... "What was that", I asked? and he answered "her pump".
My answer to that was, "well, if her pump drew less than the generator out put, what would that matter?" He answered, "well, I don't think it was less!
I'm thinking, buy once, cry once!"
SR
/ which portable generators do people have #424
SR
If you draw to much power wouldn't it just kick the generator breaker?
Reset the breaker its probably fine.
/ which portable generators do people have #425
Looks like THAT generator made some smoke, so back to buy once cry once! lol
SR
/ which portable generators do people have #426
Can’t be much pressure, do you run appliances on gravity alone?
/ which portable generators do people have #427
The gravity spring at the ranch is 2 miles away... the pressure at the house is 34 psi... always the same.
It works fine unless you are trying to irrigate or hand water outside...
Talked about adding a booster pump but the water pressure has served since the 1860's.
/ which portable generators do people have #428
All this talk of spring water...
My water comes from a spring that has been in our family I know since at least my great great grandfather...
That would be mid 1800's...
Never been dry...
Spring box with a spring house and pump...
Runoff basin flows into the spring house from the pump foot located in the spring box...
It's good water with the occasional crayfish and spring minnow...
/ which portable generators do people have #429
A lot depends on the ambient temperature. I used to do a food booth at a craft fair. We found a wonderful 6' cast iron griddle, and found that a 20 lb. tank would not provide enough gas, so bought a 100 lb. tank. There was no room for a 100 lb. tank under the grill, so we dug a hole and set the tank in the hole. Of course, it iced up. When we dug the tank out it, the dirt around it was a solid block of ice. Keep a heater on that little 20 lb. tank and it will work fine. Otherwise, the propane cools by evaporative cooling until it won't evaporate any more. A larger tank has more surface area, so the propane stays warmer, but if you plan on running a propane generator in sub-zero weather, some means of heating the tank is a good ideal. A system that tests fine in the middle of the summer may starve and die at 10 below.
Good post.
Here is a chart showing available Btu's, tank size and ambient temps.
/ which portable generators do people have #430
SR
I'd like to know what type of well she had that an 8750 wouldn't start it... It sure wasn't a regular 2" jet, or 4" residential well. ...
/ which portable generators do people have #431
I doubt it was the well or pump that was the problem...
With HF, it's hit or miss whether what you buy is junk THAT day or if it will last a little while...
Apparently, her luck is like mine!
SR
/ which portable generators do people have #432
Me too. I can run my whole house on my 10KW Miller Bobcat even tho 8K would suffice. Maybe when she got it home and her hubby found out it didn't come with a wheel kit or battery he told her to take it back.
/ which portable generators do people have #433
Here's my guess: They are Harbor Freight buyers. Their power went out. They hooked the generator to the dryer outlet and threw the generator breaker. They never did pull the Main or the meter. So, the generator died laughing.
/ which portable generators do people have #434
That's very possible too. They were trying to supply power to the whole neighborhood on their HF gen.
/ which portable generators do people have #435
i have the 8750, 7k running. my well is 3/4 horse, gen barely grunts when the well kicks on. HF generators are highly recommended.
/ which portable generators do people have #436
Well, I was there when she brought it back. I heard her conversation with the manager and I saw the genset... The generator did have a wheel kid, not sure about the batt...
She wanted to return it, NOT a replacement.
It looked like smoke came out of it, other than that, it looked new.
She talked like a knowledgeable lady about mechanical things and said it crapped out on first use.
The only thing I heard about a pump was, what the manager told me after she left...
From what "I" gathered, it was a "buy once cry once" deal...
SR
/ which portable generators do people have #437
SR
I was at HF a couple months ago, early morning first day of a sale where they were selling those 8750 gen sets. I wasn't there for one but there were 10 ahead of me that were. They didn't come with battery or wheel kit and the sale ad stated that yet the first 3 I saw go out the door didn't buy the wheel or battery.
Now I know why she returned it. She let all the SMOKE OUT.
I was there for and bought a smaller 3500W inverter generator to use with my camper.
/ which portable generators do people have #438
I went to HF on Saturday to purchase a predator 3500 inverter generator. They were sold out so I asked for a rain check as the last day of the sale was Sunday, the manger said they had 40 coming in on Wednesday but close to 30 of them were already sold and she figured the rest would be sold before they even arrived.
I know honda and yamaha are the gold standards, but I have read many positive reviews on the predator and figured it is worth a shot. I think I will purchase the one year extended warranty for $80, you can get the two year for $130. Even with the warranty it is still $200 less than Northerns powerhouse which looks exactly the same as the predator and $1200 less than the honda.
When I asked the manager who did their warranty work she said they just give you a new one and then you would get the 90 day warranty or would have to purchase the extended warranty again. I didn't ask but I think if you bring it back within the first 90 days the extended warranty would still be good. I will have to ask when I pick it up on Wednesday.
My wife insisted on electric start which the honda did not have on their 3000 watt inverter.
/ which portable generators do people have #439
When I was at Northern I asked if they work on the predator I was told by the salesman they do. Which tells me I would be able to purchase parts through them if needed.
/ which portable generators do people have #440
That's the one I bought in Dec. plus bought the extended warranty because the 90 day will be up before I take it camping. It runs super quiet (less than 56db at 24'.
Per instructions I ran mine for 6 hours with about a 70% load to break it in then changed the oil. Very happy with the easy electric start but it is heavier than expected. Mine weighs about 110 lb with a full tank of gas. I made a lifting bracket to use my garage electric winch to lift it high enough to get in the truck bed and its short enough to fit under the tonneau cover.
