which model lifts 2500+
/ which model lifts 2500+ #21
Now that you two are done fighting... :).
Why whould one want to lift 2500#'s with a FEL?
As I mentioned in my first post:
(21) bundles of shingles at 80#'s
(2) 42" forks at 100#'s
(1) QA Frame for forks at 200#'s
(1) oak skid at 20#'s
Total: 2100#´s
In this situation, the rear end of our tractor was to just touching the ground. This is unsafe for travel on any surface but level concrete and very slowly.
At 2500#´s lift a M59 or an 85 HP M series may be the only options.
-design
DFKRUG,
I have not yet measured the hdro pressure.. I think I will.
/ which model lifts 2500+ #23
The loader uses a funky -5 JIC hose fitting. Just stick a 3000psi guage on
in place of one hose and operate the FEL valve to relief.
My KL130 lifts a lot, and my ballast (1250# b/h) is usually mounted.
/ which model lifts 2500+ #24
Why lift 2500+ lbs with a FEL??
Well, removing the bucket allows me to lift 2800lb concrete culverts, albeit only 1.5 ft. and place them exactly where I want them. It's amazing what happens when you take a round concrete culvert that is about 5 feet high and 5 feet in diameter and sit it on its end so the open side is open to the heavens.
Turns into a rather dandy corner post:eek:
Won't move, won't pull out of the ground, won't rot, doesn't require a brace:D
/ which model lifts 2500+ #25
I bet you could fill it with dirt, paint the outside and have a dandy planter too. Be the talk of the town!
jb
/ which model lifts 2500+ #26
I have yet to implement my idea to place a mailbox inside one, cut a hole for the mailbox door, and dare somebody to drive by "knocking mailboxes" :eek:
Nice to have a supply of these for various uses.
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
(12) John Deere 1.5bu. Seed Boxes (A65640)
(12) John Deere...
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
2016 John Deere 6155R (A64119)
2016 John Deere...
John Deere Fork Attachment (A62613)
John Deere Fork...
2019 KENWORTH T880 (A65643)
2019 KENWORTH T880...
