which model lifts 2500+
/ which model lifts 2500+ #21
Now that you two are done fighting... :).
Why whould one want to lift 2500#'s with a FEL?
As I mentioned in my first post:
(21) bundles of shingles at 80#'s
(2) 42" forks at 100#'s
(1) QA Frame for forks at 200#'s
(1) oak skid at 20#'s
Total: 2100#´s
In this situation, the rear end of our tractor was to just touching the ground. This is unsafe for travel on any surface but level concrete and very slowly.
At 2500#´s lift a M59 or an 85 HP M series may be the only options.
-design
DFKRUG,
I have not yet measured the hdro pressure.. I think I will.
/ which model lifts 2500+ #23
The loader uses a funky -5 JIC hose fitting. Just stick a 3000psi guage on
in place of one hose and operate the FEL valve to relief.
My KL130 lifts a lot, and my ballast (1250# b/h) is usually mounted.
/ which model lifts 2500+ #24
Why lift 2500+ lbs with a FEL??
Well, removing the bucket allows me to lift 2800lb concrete culverts, albeit only 1.5 ft. and place them exactly where I want them. It's amazing what happens when you take a round concrete culvert that is about 5 feet high and 5 feet in diameter and sit it on its end so the open side is open to the heavens.
Turns into a rather dandy corner post:eek:
Won't move, won't pull out of the ground, won't rot, doesn't require a brace:D
/ which model lifts 2500+ #25
I bet you could fill it with dirt, paint the outside and have a dandy planter too. Be the talk of the town!
jb
/ which model lifts 2500+ #26
I have yet to implement my idea to place a mailbox inside one, cut a hole for the mailbox door, and dare somebody to drive by "knocking mailboxes" :eek:
Nice to have a supply of these for various uses.
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
2023 Cub Cadet Pro Z 972 (A64127)
2023 Cub Cadet Pro...
2007 Freightliner Columbia 120 Single Axle Day Cab (A62613)
2007 Freightliner...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
24in pin on excavator tooth bucket (A61307)
24in pin on...
