Which Kubota
/ Which Kubota #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I want a 60-70 hp 4wd Utility tractor. Something built a little heavier than the usual compact. Think I want a wet clutch too. What Kubota models should I look at? 15 years old max.
/ Which Kubota #2
With no use requirements other than HP...only summary info is provided:
60 hp at the PTO is a transition area for Kubota.
Kubota L series:
Max out at about 60hp...smaller frame, smaller utility tractor, loader work, mowing, limited agricultural, not targeted for heavy ground engagement tasks.
Kubota M60, M5, M6 series:
50hp and up, typically larger frame, heavier, targeted as agricultural use tractor
Kubota MX series
50 to 60 hp, targeted as utility tractor and bridge between L and M series.
If you're serious, search YouTube for "Messicks" for some short, informative videos on the Kubota tractor product line.
Good Luck!
/ Which Kubota #3
M7040. Horsepower, compact, bulletproof, pre-emission and lots around. One of the best Kubotas ever made. 70HP.
Tractors are like barns. You always need bigger.
/ Which Kubota #4
Both the Grand L and MX series Kubota tractors in the 60HP range, have been around for quite a few years. I have an L6060 HSTC and an MX5800 HST. Both have been bullet proof.
The M series Kubotas offer more power $ weight but if you want an HST transmission, the choices are limited.
/ Which Kubota #5
Agree with both Mr. BDHSFZ6 and Mr. Sixdogs!
I've put 1000 hours on my 60 hp MX6000 and love the power for it's size, along with the HST transmission...though a right priced M7040 might get me considering a swap, even though it is likely overkill for my 35 acres.
/ Which Kubota #6
What are the main duties for the tractor? I have a M5040... it is great, but if I was searching again I would go with a larger engine, like the M7040 mentioned earlier, and a six speed transmission. (Which makes it a 12 with the high low, mine is only 8 total). For brush hogging I often need a 3 and a half gear that I can never locate lol
This issue alone highlights the functionality of a HST. I've never operated a MX, but if you want a HST then a MX with the biggest motor you can find and or afford is probably the way to go.
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2023 J&J TRAILER (A65643)
2023 J&J TRAILER...
