Which grease to use?
/ Which grease to use? #1
magnatic
Southern Ontario
2006 BX2350
I've always thought that wheel bearing grease was superior to extreme pressure grease or multi-purpose grease. Yet while reading a tube today, it indicated that wheel bearing grease "may" be used for "certain" farm applications.
Which is the best for tractor, loader, mowerand snowblower use?
Thanks.
/ Which grease to use? #3
Kubota manual says NLG1 2 grease for ball bearings and roller bearings.
Look for that spec (nlg1 2) and you should be good to go.
/ Which grease to use? #4
Wheel bearing grease is most suitable for high temperatures. Dont go nuts over which grease, a 5 gal. can of Molly grease, its EP and a pump to reload your gun is all that is needed.
/ Which grease to use? #5
I like Valvoline Crimson Red. For off road applications. Find it at NAPA. Philip.
/ Which grease to use? #6
For general purpose grease, I use Sta-Lube Moly-Graph. The worst thing you can do is mix grease types. If your application uses lithium base grease, stay with lithium base.
/ Which grease to use? #7
We started using this on our new JD round baler last year and use it on about
everything now.
thumbnail.asp
John Deere Multi-Purpose SD Polyurea Gun Grease - TY6341
/ Which grease to use? #8
I used Mystik JT-6 Hi-Temp NLGI #2 but I found out that it belongs to old Hugo Chavez. Now I don't know what to use. I won't finance him though.
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
UNVERFERTH GW530 GRAVITY WAGON (A64278)
UNVERFERTH GW530...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
