Which grease to use?
/ Which grease to use? #1
magnatic
Southern Ontario
2006 BX2350
I've always thought that wheel bearing grease was superior to extreme pressure grease or multi-purpose grease. Yet while reading a tube today, it indicated that wheel bearing grease "may" be used for "certain" farm applications.
Which is the best for tractor, loader, mowerand snowblower use?
Thanks.
/ Which grease to use? #3
Kubota manual says NLG1 2 grease for ball bearings and roller bearings.
Look for that spec (nlg1 2) and you should be good to go.
/ Which grease to use? #4
Wheel bearing grease is most suitable for high temperatures. Dont go nuts over which grease, a 5 gal. can of Molly grease, its EP and a pump to reload your gun is all that is needed.
/ Which grease to use? #5
I like Valvoline Crimson Red. For off road applications. Find it at NAPA. Philip.
/ Which grease to use? #6
For general purpose grease, I use Sta-Lube Moly-Graph. The worst thing you can do is mix grease types. If your application uses lithium base grease, stay with lithium base.
/ Which grease to use? #7
We started using this on our new JD round baler last year and use it on about
everything now.
thumbnail.asp
John Deere Multi-Purpose SD Polyurea Gun Grease - TY6341
/ Which grease to use? #8
I used Mystik JT-6 Hi-Temp NLGI #2 but I found out that it belongs to old Hugo Chavez. Now I don't know what to use. I won't finance him though.
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2012 Chevrolet Equinox AWD SUV (A64557)
2012 Chevrolet...
Small Cow (A64557)
Small Cow (A64557)
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
2025 Miscellaneous Mini Excavator Attachments (A64553)
2025 Miscellaneous...
