which grease are you using
/ which grease are you using #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
which brand and type of grease you all using on your your mahindras thanks ed
/ which grease are you using #2
I use whatever I can find that's cheap. Loaders and hoes get greased so much that whatever you use will not wear out or fail you in anyway.
/ which grease are you using #3
Traveller " Premium Truck and Tractor grease", red in color, for use in extreme pressure applications ( Tractor Supply Brand ) Bought 4 cases - 48 tubes - about 4 yrs ago when they marked them down from 3.99 to .99 ...... Takes forever to wash off your Hands ! ! ! !
/ which grease are you using #4
I've been using marine grease on my stuff :shrug:
/ which grease are you using #5
I grab just whatever figure as long as putting something in it. Chevron"ultra duty",Mystik Hi-temp to name a few laying around.
/ which grease are you using #6
I use what ever NGLI #2 grade (lithium) grease is on sale, Like Old Pilgrim said, if you grease it as per the manual you will never have any trouble. The only thing that would require a specific grease would be like a high speed bearing. The throw-out bearing is the only one that comes to my mind right now and the grease's with the above rating will cover that also.
/ which grease are you using #7
for starters your way ahead of most by actually caring and greasing your equipment, lol
personally I like lithium grease that is fortified with molybdenum, aka moly grease. Brand wise I like Mag1 greases and lubricants, they are a good value, meets top specs, are open with technical info on their products and best of all have free shipping on amazon.
/ which grease are you using #8
Ill second the NLGI grade 2 for almost all locations. Then just make note if there are any locations that specifically specify something else special is necessary such as busynsr pointed out. This is coming from an old crusher guy where mining equipment sees some of the most severe conditions!
Beware there are some locations that you should NOT use molybdenum based grease- as a general rule-of-thumb such as in a roller bearing but is excellent for use in bushings such as rod ends and joints of a loader or back hoe where there is high friction but low movement. I would never use it say, on a pillow block bearing or a PTO U-joint.
IMHO, a tractor guy should have 3 grease guns: 1 that is commonly used with NLGI grade 2, the second with a synthetic lithium, and a third with Moly.
2016 Cadillac XTS Sedan (A61574)
2016 Cadillac XTS...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
