Which box blade?
/ Which box blade? #1
realmccoy10751
NC
Kubota B7510
I just purchased a B7510 w/302FEL and reading around on the forum it seems to me that I will need some kind of counter weight to help with FEL work. I need a box blade anyway so would this be a good counterweight? I haven't recieved my tractor yet so I was thinking on Monday I would call the dealer and have him get me a box blade as well. Does kubota make these or should I go with another brand. What kind of prices are these usaually and what size would be good for my tractor. I might as well finance it huh?
/ Which box blade? #2
For a 7510 I would go no larger than a 48" box blade, and even a heavy 48" blade may be a bit much for that tractor. Midwest make a light 48" box blade called the BB15-48. It would be a good fit for your tractor. The B7510 is very light, under 1400# so you are limited to the size box blade you can handle.
Edit : You might want to check out this thread too: Box Blade :: PHOTO COMPARISON
/ Which box blade? #3
I had a B7500 and used a 48" box and also filled the rear tires for better traction...it needed it.
I would recommend a BB that has the double lug attach point instead of a single pin for the 3pt lower arms, they are easier to hook up and are stronger. I know Bush Hog makes theirs like this but there are several others that do also.
/ Which box blade? #4
I use a Howse EB48 behind my B7510. It weighs 394 pounds and seems about right for both width and ballast. I use the FEL a lot and have never had a problem with the tractor feeling light in the rear.
Depending on the soil and type of work you will be doing tire filling might help. Try it for a while without and see if you find yourself spinning the tires a lot, if so fill them. I used 2 gallons of anti-freeze and the rest water because we have very little freezing weather in East Texas, filled 75%.
Bill Tolle
2002 FORD F-250 SUPER DUTY LARIAT SERVICE TRUCK (A64276)
2002 FORD F-250...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2022 Bobcat MT100 (A64126)
2022 Bobcat MT100...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
