Which box blade?
/ Which box blade? #1
realmccoy10751
NC
Kubota B7510
I just purchased a B7510 w/302FEL and reading around on the forum it seems to me that I will need some kind of counter weight to help with FEL work. I need a box blade anyway so would this be a good counterweight? I haven't recieved my tractor yet so I was thinking on Monday I would call the dealer and have him get me a box blade as well. Does kubota make these or should I go with another brand. What kind of prices are these usaually and what size would be good for my tractor. I might as well finance it huh?
/ Which box blade? #2
For a 7510 I would go no larger than a 48" box blade, and even a heavy 48" blade may be a bit much for that tractor. Midwest make a light 48" box blade called the BB15-48. It would be a good fit for your tractor. The B7510 is very light, under 1400# so you are limited to the size box blade you can handle.
Edit : You might want to check out this thread too: Box Blade :: PHOTO COMPARISON
/ Which box blade? #3
I had a B7500 and used a 48" box and also filled the rear tires for better traction...it needed it.
I would recommend a BB that has the double lug attach point instead of a single pin for the 3pt lower arms, they are easier to hook up and are stronger. I know Bush Hog makes theirs like this but there are several others that do also.
/ Which box blade? #4
I use a Howse EB48 behind my B7510. It weighs 394 pounds and seems about right for both width and ballast. I use the FEL a lot and have never had a problem with the tractor feeling light in the rear.
Depending on the soil and type of work you will be doing tire filling might help. Try it for a while without and see if you find yourself spinning the tires a lot, if so fill them. I used 2 gallons of anti-freeze and the rest water because we have very little freezing weather in East Texas, filled 75%.
Bill Tolle
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
