where to do hydro oil
   / where to do hydro oil #1
chubby
Georgetown, De
Kioti DK50SE hst w/hoe & John Deere 3720 hst cab & John Deere 3120 hst w/375 hoe
I am at the 400 hrs mark, time to change fluid for the first time. I have a hoe that stays on and only comes off with the snow. My issue is where to add the new fluid. Looks like the hoe return line must be removed to add fluid. Are there any other spots or do I have to remove the return quick disconnect to add the fluid?
   / where to do hydro oil #2
The Hoe return line is the fill port.
   / where to do hydro oil #3
Say what? My hoe's hydro lines plug into the two remote connectors. I have a separate fill spot at the rear. :confused3:
   / where to do hydro oil #4
Yea, theres a kit supplied to the dealers that comes with the backhoe attachment, some dealers apparently think they know more than Kioti and don't install them.
Depending on how many backhoes your dealer has sold, he probably has the kits stacked up like cordwood.
There is a vent tube that gets installed in place of the little plastic plug that is up and to the left of the PTO shaft.
Then there is another fitting that replaces the fill plug for the HYD, the return on the Backhoe gets plugged into that.
My hoe was lacking power, it has more power since the kit was installed, and the hyd fluid stays cooler.
It clearly shows the kit in the owners book for the Hoe, sect. 13-4
   / where to do hydro oil #5
Your Backhoe would run cooler and stronger if it was plumbed right.
   / where to do hydro oil #7
Stronger is good and who doesn't want to be cooler. :cool2: I'm in!
Tell your dealer you want the kit your BH came with.
   / where to do hydro oil #8
I'll give him a call on Monday, thanks for the info on this. :thumbsup: Is this something he needs to put on or can I do this at home?
   / where to do hydro oil #9
You can do it easily, If you have a hard time [which I doub't] I'll take photo's.
   / where to do hydro oil #10
2 things: the new vent goes where there is a bolt, not a plastic screw (at least in my case) and I did not find myself having any more power than before.
2006 Hyundai HL740-7 Articulated Wheel Loader (A56857)
2006 Hyundai...
2011 Ford F-150 Crew Cab Pickup Truck (A56858)
2011 Ford F-150...
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2014 Jeep Cherokee Sport SUV (A56859)
2014 Jeep Cherokee...
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
