where to connect to trailer
   / where to connect to trailer
Thanks for all your time and answers. I do have one additional question. I have already read the other posts on this subject but need more clarification.
Loading my tractor for tongue weight to be correct.
Trailer 22' tilt 14k Truck 2015 ram 2500 6.4 gas
Tractor Kioti rx7320 with cab loaded rear tires I think 9000 lbs
I think I will purchase a tongue weight scale about 165.00
My question Is to know the exact tongue weight with the tractor in different positions the trailer cant be hooked to the truck (Unless I am missing something that does not sound like a good idea to do that),
Is there a way to hook up the trailer to the truck, load the tractor to where I think it should be, then raise the trailer up so I can measure the tongue weight? I could then adjust back and forth until I get it right on the money. Once I do I can mark where it needs to be and that wont change unless attachments are added at some point.
So, tell me the error of my way :)
Sorry for the greeny questions.
The Bible says When there is no skillful direction, the people fall, But there is success through many advisers.
   / where to connect to trailer #12
So the chain goes through the twisted clevis hook? Where did you get that?
A twisted shackle is a safer option than the twisted clevis. Rated at a much higher load because the pin isn't free to move around. Make sure the pin diameter is close to the size of hole in your draw bar also
   / where to connect to trailer #13
even if the loader is attached to the tractor? Any suggestions for brackets for my Kioti?
Also this is probably overkill and maybe redundant but I am considering a set of bonnet tie downs just for the front tires, just an added protection. I had thought about Chalks for the front but did not like what was available.
The chance of getting a ticket for it are pretty slim but yes they want to see securement on anything that moves separate of the machine body.
   / where to connect to trailer #14
A tilt deck makes it pretty easy to know where the load balances. My tilt pivots directly centered of the axels. Just drive on until it goes down and then move forward another foot or so.
makes sense, Does the twisted shackle attach at the lower link of the 3 point and if so mine is a category 2 so 1 1/8 diameter cant seem to find a twisted shackle beyond 1/2" I am pretty sure I dont know what i am talking about Help :)
   / where to connect to trailer #16
   / where to connect to trailer #17
This is how they do it in my neck of the woods. Just 4 simple straps and it ain't going anywhere. (Baler is tied down too) No heavy chains to drag around or need for fancy shackles.
I often see threads where people claim that tractors don't have good tie down points or something. I don't really understand where they get that from.
   / where to connect to trailer #18
Agreed, if it has tires you have tie downs, if the trailer has tie locations. Some trailers suck.
great pics and awesome info. I have been looking for bonnets for tractors and not much out there, You showed how it is done:) I do have one question. 1 post i read talked about the fact that having only 1 ratchet pulling in 1 direction would be an issue as pulling a trailer you have stress when your starting in one direction and stress in the other direction when you are applying the brakes.
I guess a guy could take and cut off the end and add a second ratchet so it is pulling in both directions. I like how you were able to secure the back tires as well.
I am probably over thinking this but I know myself and If I lost a load and injured or even killed someone i would not be able to live with it.
Thanks for all the input you guys are great ! :) Kind Regards, Joe
   / where to connect to trailer #20
Yes, if you look close, you will see a chain front and rear pulling both directions. Then the strap is doing the same thing.
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2015 Chevrolet Cruze Sedan (A55853)
2015 Chevrolet...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
2024 Frontier FL1061S Hydraulic Flail Mower (A55315)
2024 Frontier...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
