Looking for a tooth bar for a New Holland T2310 with a 250 loader. Where is a good place to buy? Also, is bolt on replaceable teeth worth the extra cost?
I bought a W.R. Long toothbar from my dealer as part of my tractor buy. Your dealer should be able to order a toothbar for you, but may not have any in stock. You can also find toothbars at Everything Attachments here: Tractor Bucket Bolt on Tooth Bar. They sell both W.R. Long and Construction Attachments models, and are an advertiser on TBN.
The toothbar has an elongated mounting slot in each end. It is designed such that if you drill the holes in your bucket at the front of the slot instead of the rear, the bar can be flipped back into your bucket when you need a smooth cutting edge by loosening the bolts and pulling the toothbar forward to clear the cutting edge. I unfortunately neglected to remind my dealer of this before it was mounted, and he drilled the holes at the back of the slot. If I want to use the smooth cutting edge, I have to remove the heavy toothbar first. HTH.
I purchased a Construction Attachments toothbar from Everything Attachments a few months ago. Quick shipping, friendly service, and good price. I drilled my holes close to the front of the slot in the tooth bar planning on having the ability to loosen the bolts and flip it up out of the way if necessary. Unfortunately, the part of each tooth that goes under the bucket doesn't clear the bucket with the tooth bar all the way forward. Other brands may clear but not the CA. I have used the bucket in dirt and gravel and it appears to be sturdy and well built.
