Where might we find an adjustable orifice
/ Where might we find an adjustable orifice #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
We are getting parts together for a new project but are having trouble locating a source for a hydraulic adjustable restrictor or orifice. We will be needing one to slow a hydraulic motor and we think an adjustable model might be better suited than a fixed model. We have tried Parker, McMaster's, Tractor Supply, and even eBay without luck so far.
It's pretty sad when you can't find what you are looking for at eBay. Anyone have any sources that we are not aware of?
/ Where might we find an adjustable orifice #2
Mike,
Here is what you need. I have used them and they work. Here
/ Where might we find an adjustable orifice #3
there are two kinds, a simple kind where the bolt screws into the oil flow (which obviously restricts the flow) and one that divides the flow (I don't know how) so that the gpm does not get choked at the pump.
These guys have a catalog with stuff in it that I did not even know existed so see if they can help you:
If these guys aint got it you don't need it!
Their web site does not list everything they can get, their catalog looks like a phone book!
Good Luck /forums/images/graemlins/smile.gif
/ Where might we find an adjustable orifice #4
<font color="blue"> hydraulic adjustable restrictor or orifice. </font>
Mike
Sometimes it's what you call the item when doing a search. /forums/images/graemlins/wink.gif
Try ( hydraulic flow control ).
/ Where might we find an adjustable orifice #5
<font color="blue"> </font> so that the gpm does not get choked at the pump.
This is probably a bypass valve back to the hydraulic resevoir. If your ambitious a properly rated manually operated globe vale or a pressure regulator could probably be adapted for use.
I'd stick to the commercial version which should be able to maintain a set pressure to the hydaulic implement.
Egon
/ Where might we find an adjustable orifice #7
Jerry
I don't know a lot about hydrulics but I have to slow the chute rotation of my snow blower. I was thinking about putting a restrictor in the line and read your post.
This is from the link you posted:
<font color="blue"> "F SERIES Adjustable flow control valve provides precise control of oil flow and shut-off in one direction and full flow the opposite direction."
</font>
Does this mean the chute rotation will be slowed in one direction and not in the other? If so, will I need to get two to control both directions?
Al
Al that is exactly the way we understand that particular valve to work, that is you would need two. We also suspect that a number of valves that will restrict the flow going both ways so we are still shopping the lists that everyone was kind enough to supply. I think we are going to opt for a simple adjustable valve over a fixed counterpart but we'll see.
/ Where might we find an adjustable orifice #9
You will need one for each hose that connects to a double acting cylinder.
The restrictor will restrict flow in one direction and allow full flow in the other. Just make sure you connect it so that the restricted flow is the direction going to the cylinder.
/ Where might we find an adjustable orifice #10
That's right. Mad outlined it below.
/ Where might we find an adjustable orifice #11
/ Where might we find an adjustable orifice #12
An adjustable flow divider would work and you would only need one before control valve. I have a Sun Hydraulics 0-16gpm pressure compensated for my 8gpm hoe on a 23gpm circuit. Bought 2 for $50 ship incl on E-Bay, reg $85 ea. Cheap aux hydraulics.
2017 John Deere 825i XUV Gas Utility Cart (A59228)
2017 John Deere...
2001 International 4000 DT 466E (A60462)
2001 International...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
72in. Hydraulic Dual Cylinder Grapple Skid Steer Attachment (A59228)
72in. Hydraulic...
