Where is coolant?
/ Where is coolant? #1
camillit
My 2007 2305 with 160 hours has started eating coolant. It runs great, no drips at all, no odors, no smoke. In cars when this occured it was bad head gasket, but then you would see white smoke or bubbles in the radiator. Ideas?
/ Where is coolant? #2
Hiya,
Is your oil level "over full" or does the oil look like chocolate milk? When was the last time you looked at the coolant level before you discovered it was low?
Tom
/ Where is coolant?
oil is and always has been normal..amount, looking, smelling and feel. check it every other use.
/ Where is coolant? #4
Hiya,
When a Diesel pops a head gasket you will know it, they will drop that cylinder. How much coolant is it losing per hour of use? Is the radiator clear of chaffe in the fins? If the core area of the radiator is plugged, it will keep the coolant hot and tend to evap more water off. Water still evaporates from coolant, if the loss is minimal for the hours worked, you may be simply steaming it off.
Another thought, have you checked the ratio of glycol to water for the correct 60-40 mix? If you have been adding water only for the make-up, you may be making the issues worse by diluting the ratio and evaporating more off.
Have you checked the weep hole in the waterpump housing for wetness or rust deposits? I have seen them drip and clear everything on the way down to the ground. Most times they will only drip when the engine is running and hot.
If you can't find anything leaking, go get a pressure tester, pump it up to about 20PSI and see what happens to leak out.
Tom
Tom
/ Where is coolant? #5
What Tom said,
Check the water pump weep hole. They tend to leak out the weep hole especially if they sit for extended lengths of time or run hot.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
1995 Freightliner FL70 S/A Dump Truck (A64556)
1995 Freightliner...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
TEST YOUR BID BUTTON! (A64278)
TEST YOUR BID...
1200 GALLON FLAT BOTTOM POLY TANK (A64278)
1200 GALLON FLAT...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
