Where does this go?
/ Where does this go? #1
Clay45
SC
Kubota L2050DT
I have one of these : Heater Plug
Don't recall why I got it and don't know how/where to install it nor where it gets its power. Does it hook into ignition somehow?
Thanks in advance.
/ Where does this go? #2
#1 in picture
Power comes from key switch,when turned left.
/ Where does this go? #3
Hoye is showing the same Thermal/Glow plug as my Ym2000. If your Ing. switch is the same then here's a wire Dia. Just a lead from the R2. Circuit. Turn the switch to the left.:) If you don't have a Fuel Bowl which I don't. And Rarely have I had to use the TS.. So here is my Quick setup. Works great and the only thing you may need to do is give it a little squeeze to blow the air out of the line if needed. Wait until it gets hot so the TS is open. Then I squirt what's left it back in the Tank. ;)
/ Where does this go? #4
In the diagram, it shows a horn switch. I would love to find one of those to hookup.
/ Where does this go? #5
Here's proof it's there. And mine works. Think back to the Road Runner in Cartoons and that's what it sounds like. Can't help not to smile.:D
/ Where does this go? #6
I tried Hoye, Fredrisks and others, but they no longer carry the switch. My YM2610 came with a horn up front betwix the head lamps.
Hey, what's that added switch down below you had added?
/ Where does this go? #7
Headlights. The Black toggle is my Rear work light. Tach. behind the Steering wheel. It was setup like this when I bought it. I had the switch out just to see how it was cut in the dash. It's to clean of a cut. Perfect!. IMO. it's Org.. Trust me! I left Steve at Spalding a Chk. for this one until I could get back to pick it up. :D
Thanks gents! I flat forgot about starting this thread. My 1401 has horn button and turn signal switch that don't function.
Regards,
Clay
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A65563)
2007 Isuzu FTR...
(2) TOOL BOXES (A62613)
(2) TOOL BOXES...
JOHN DEERE 544J SUPER TRACTION WHEEL LOADER (A65053)
JOHN DEERE 544J...
Gasoline Concrete Mixer 8.0 Honda (A62679)
Gasoline Concrete...
