where does it go GC1710
   / where does it go GC1710 #1
rbperk
staley,nc
mitsubishi 2001
I have the 1710 with the backhoe and I have disconnected it from the tractor.
The problem I'm having is how to hook the hoses back together on the tractor.
They are marked red blue and yellow. Which one hooks back together?
Thanks.
   / where does it go GC1710 #3
One has blue and another color, one has only blue. This should be a male/female to connect and close the hydraulic loop.
   / where does it go GC1710 #4
iirc blue is return and is the one you run connected w/ backhoe off. if labels missing off tractor side that may help clue you in.
if you been running tractor w/ backhoe off and return not connected...well...you in for world of hurt.
Thanks guys, I got it now.
   / where does it go GC1710 #7
What I do ....... after it's hooked back up and working correctly, put your own color coded zip ties on the matching lines, then also take a picture to keep on your phone for future reference (just in case)
I do that before I take stuff apart (phone picture); has made life easier when putting things back together.
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2012 Bobcat S850 (A50120)
2012 Bobcat S850...
1992 Peterbilt 377 Sleeper Cab (A52748)
1992 Peterbilt 377...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2007 Godwin Pumps GHP45KW-RC S/A Towable Trailer Generator Set (A50322)
2007 Godwin Pumps...
