Where do you buy tires? What brands to avoid.
   / Where do you buy tires? What brands to avoid. #61
I went at the tire with a crowbar and a cat's claw. No go. And too dang hot outside for me to be persistent. 95 right now. So I gave up and either I'll take it to the local shop (most likely) or to my brother-in-law's shop and get him to help me with his tire tools.
Try my FEL trick. Lay tire on ground, with bucket edge near bead. Set block of wood on side wall, press down with bucket.
Lift bucket, turn tire, repeat. Goes pretty quick.
For re-seating bead, a rope around centerline of tire, with a turn-binder stick to wind it tight, then a little shot of air in the valve, always gets it done.
I've done this many times on everything from cars, to trailers, to garden tractors. Admittedly, I have not tried it on CUT rears, but can't see it not working the same there.
   / Where do you buy tires? What brands to avoid. #62
Found some quick vid's:
Removing:
Re-seating:
Wetting the bead really helps, I didn't see this guy do that, but I skipped to the good bit.
Likewise, pushing tire off rim, I use a block of wood to focus pressure on the bead, rather than pushing loader edge across entire tire.
   / Where do you buy tires? What brands to avoid. #63
I don't see how an out-of-spec front to rear ratio would have an effect when in two wheel drive. On my tractor the front is mechanically and completely uncoupled from the rear when in 2wd. Yes, everything forward of that spins but there is no tension from the rears to push or pull on the front system and the front diff is open as well.
You answered your own question, everything inside is still rotating
Thanks. Unfortunately I brought them back home. My tractor is 45 minutes away. I could certainly take them back down there when the tires come and try that using my brother-in-laws tire tools but I'll probably just be lazy and take them to the tire place.
I have also noticed that even the weight of the tractor on the deflated tire will break the bead so that might also be an option in the future.
So? It is all rotating freely. Nothing to put tension on the system that I can think of.
I dropped the tires and wheels off at the local tire shop. This is an old locally owned shop that has been here for decades. I was surprised to see other tractor tires being done and in the parking lot out back they were changing tires on a big 6x4 dump truck.
I didn't ask how much it would cost but it doesn't really matter at this point.
   / Where do you buy tires? What brands to avoid. #67
Just bought 2 Carlisle from Amazon for L3400. They seem to be good quality and stapped MADE IN USA
   / Where do you buy tires? What brands to avoid. #68
The fronts on my Kubota L4400 are worn out. Low hours on them but 20 years. They are R-1s. 8.00x16. Goodyear. I want to replace them.
But where do you buy tractor tires? I have a dealership nearby who could do everything but I'm assuming that would be very expensive. Online it looks like shipping would be expensive.
On line, Goodyear R-1s in my size seem to run over $300 each. That's more than I'd prefer to spend.
I would assume I could do this work myself? I have easy access to tire pry bars etc. I use tubes on the front so setting the bead is no problem.
I've got amazon Prime and can get free shipping on what they offer but most of it is names I don't recognize and presumably from China.
A local auto tire place has replaced tubes for me in the past but I'm not sure they can get new tires for me. I can check of course.
Also, what brands to avoid. Carlisle which is now Carlstar or something like that pops up a lot. Not sure if they are Chinese or not. I see quite a few tires made in Mexico.
Any ideas/advice much appreciated.
You’re willing to pay for the other junk you mentioned, but not spring a few dollars for tires? 🤔
   / Where do you buy tires? What brands to avoid. #69
Go to your Kubota dealer. They had or have a tire replacement policy in place for my BX25 (16 years old). All 4 tires on rims cost me $500 Canadian +taxes. You got 20 years out of the old set why source elsewhere with little to no guarantee as to quality or longevity.
   / Where do you buy tires? What brands to avoid. #70
The most recent tractor tires I’ve purchased are CEAT R1 radials. I’m very happy with them. The sidewalls on the original Good Years were breaking down. 2017 5100M 4wd.
2019 CHEVROLET SILVERADO 11FT FLATBED (A58018)
2019 CHEVROLET...
Bucket (A55973)
Bucket (A55973)
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
TANK MANIFOLD (A55745)
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
