When will it fall?
/ When will it fall? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I thought I'd post this for kicks & grins.
This tree is just a skip down the road from my house & mailbox. It is on TVA property and is leaning away from the road. (I always try to notice a leaner towards the road because in a storm, it usually means I'm the one out in the weather, clearing the obstruction from the roadway!)
I don't know where the critical angle is.... but you can see a lump in the ground where the root ball is slowly being pushed up.
This is sort of like watching a train wreck in slowwwwwwwwwwwwwwwwwwwwwwww motion!
I've even thought about taking the backhoe and pushing or digging a bit to expedite the process. This tree will fall without damaging anything. I just get nervous that by an odd chance, a trail walker or deer might be near (the trail is nowhere near this tree so I'm just being a bit over-cautious)
I was thinking it would be fun to make a contest and the winner who picked the correct day would win a prize or something....
/ When will it fall? #2
I've seen some like this go for years and never topple. But glad it is leaning away from most potential danger.
How long has it been leaning like that?
Well, just for kicks, I'll pick July 4th.
/ When will it fall? #3
I have feeling the tree w/the bark damage next to road will hit the ground before the leaner.
wngsprd.
"I've seen some like this go for years and never topple"
I agree.
10/17 I am picking.
/ When will it fall? #4
A road commission guy told me that the number is 17 degrees. They may go for many years, but if it exceeds 17 degrees, it will fall. I was told that after seeing a healthy oak tree fall over one spring. Apparently, when it leafs out before the roots are no longer dormant, they will fall over if the exceed 17 degrees.
/ When will it fall? #5
I've got one on the back 40 with a lot more lean than that, just noticed it the other day while checking fences from recent storm. It poses no danger to the fence, maybe a horse, if it leafs out this spring, i'll cut it next fall or just wait & see how long it does take to fall.
Ronnie
/ When will it fall? #6
You'll never know when it does fall... unless you're there for the event.
It won't make a sound otherwise.
/ When will it fall? #7
Good one Wagtail!!!!! :)
That tree doesn't appear to be near falling. But pictures are deceiving.
Now this tree on the other hand...... :) It's been like this for 66 years that I know of. The mighty Oak.
Here's another pic of the same tree. Taken in 1949. Find the car in the photo. Then up and just a pinch to the right, just past the end of the pond dam. It's already leaning to the left in this photo.
/ When will it fall? #8
I am hopeless at trying to predict when trees will finally fall, they always do the opposite of what I expect, but if it's a guessing game, I'm in - I'll say the last day of September.
Like ovrszd's oak, this old ash tree has been growing at crazy angles for many years. It has been happily growing up, across and up again.
I kept on pollarding the new growth every 7 years or so for firewood and to keep the weight down. As I get older it gets more difficult to climb up there, but now I don't have to any more. When I came to have a look at it last week I found the trunk was starting to rot at the base. It is a great place for children to play, so not much option other than to take it down.
/ When will it fall? #9
Eric, I'm rooting for my old Oak. Every Summer when it leaves out I check the base for any kind of movement. I haven't taken any measurements but maybe I should to track the progress. I'll pick a few dates on the calendar this year and check the trunk with an angle finder.
I tell all the Grandkids to not play under it or climb it. Being right by the pond it's an attraction for them.
Can you imagine the pressure forces on the root system and the trunk base???
/ When will it fall? #10
If you want to speed nature up, it is easy to entice an old tree to come and meet the ground. Simply erect a new fence alongside ...
/ When will it fall? #11
Good one Eric!!!! :)
Update (though no pictures yet)
Tree is still standing/leaning.... not fallen over yet.
The bulge in the ground has gotten larger so there is more pressure there. I've debated on taking my backhoe (industrial) and from the road, scratch at the bulging rootball to speed the process... Then I think I'll wait another day to see what happens.
I keep checking after nasty storms. Darn tree should be in a Timex commercial because it's still ticking!!
/ When will it fall? #13
If a tree falls in the forest and nobody hears it, does it make a sound? I have several dead trees from the 2009 drought that also leaning. Not worth the time, effort or risk of cutting them down for the ones that are going to fall in the forest. Now the ones that may fall on a building, in the pond or across a road, those are a much higher priority.
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
2022 EZ-GO ELITE...
Kubota L2501 (A62177)
2007 Flatbed Dump (A62613)
2007 Flatbed Dump...
Kubota KX080-4 Mini Excavator (A65579)
Kubota KX080-4...
2011 PROCO 130BBL (A65643)
2011 PROCO 130BBL...
