When to go gooseneck
/ When to go gooseneck #21
As a bonus, PJ GN with two 7K axles (T8 for example) comes with a GVWR of 15,600lb. The factory will make a name plate with a lower rating if you need to stay under 26,000 lb. Our F350 has a GVWR of 11,300 so we had the trailer titled at 14,690. At least in Colorado you can only play that game once, I don't know of any way to go back up once the title work is submitted
Another good reason to go with a GN is if you ever to have tow on snow or ice. The GN just handles a lot better on slippery roads since it is loading both truck axles.
/ When to go gooseneck #22
after reading through all of the replies on this subject, another thing to consider along with the goose neck option is the issue of electric brakes on one or both axles. a 14K trailer will carry some what more than 10,000 lbs. now comes the task of stopping that load in a safe manner. i have several trailers of my own that I carry different weights of equipment on. anything under 10k goes on my trailer that has electric brakes on the back axle. any thing over 10K goes on my trailer with brakes on both axles. if I had only one trailer to work with I would have brakes on both axles just to be on the safe side. as your tryck probably weights some where in the 5,000 lb range. you take the wieght of the trailer ( mine wieght 6K ) then add another 10K of equipment on the back of it. Believe me when I tell you that wieght will over take the tow vehicles ability to stop it if you dont have enough braking power on the trailer its self. I learned this the hard way as there are idiots out there that will pull out in front of you not realizing that you could be rolling down the road with a combined wieght of 20K which will not stop on a dime. my .02 cents
/ When to go gooseneck #23
I don't think you can even legally buy a good trailer with out having brakes on both axles. I would suggest going up to 8k axles and super single tires or 17.5 last longer and dot don't look at single tires around here as much as they do tandem duals
/ When to go gooseneck #24
Im trying to get to a G/N even if I have to convert my exsisting 20' deckover to do it.
/ When to go gooseneck #25
Why do you need safety chain? I do not have safety chain on my 5th wheel... Why is the gooseneck different with safety chains?
I have considered a 10k gooseneck for my tractor. I have kind of outgrown my 16' 7k bumper tow. Part of the reason for me considering a gooseneck is because of how nice my 5th wheel tows. I was also looking at the goosneck plates that fit my bed rails for the 5th wheel hitch.
It just isn't a financial priority for me right now...
My nephew raises horses and has used goosenecks for 25 plus years I know of. Have helped him pull loads some and have used his rig a few times. His trailers and hitch have safety chains on them. It is a ball hitch maybe stronger than a pull ball hitch but still basically same design so why not have safety chains on GN if needed on bumper pull? Which I agree both need them. I must admit have wondered why safety chains are not used on 5th wheels. Then I have no experience with those design.
/ When to go gooseneck #26
I don't know how many votes we have for gooseneck's so far but throw my vote in. After about 10k, you can't beat them. The excuse about using the bed is a load of crap. Get a bigger trailer if you need " bed space". I will caution you about loading them correctly. You need more hitch weight than a bumper pull trailer. The guys who park the heavy load over the tandem dual axles and tow with 3/4 ton truck are asking for a wreck. Weight on the rear truck axle is for pulling and braking not bragging rights. If the trailer brakes are 100% and adjusted correctly there should not be a problem, but in a panic stop I wouldn't want someone's death on my mind if I lost control of my rig.
I personally do not like goosenecks. I had one and the loss of bed space plus not be able to pull it with my SUVs made it very limited on how I could use it.
Something to think about?
There have been times in the past that I've used my wife's SUV for towing stuff instead of my truck, and eliminating that option would be a negative side effect. Thanks for pointing this out. I'll have to factor that in.
/ When to go gooseneck #28
SUV's tow considerable less then 3/4 and 1 ton trucks. So yes if you are moving loads under 8K including a trailer than a gooseneck is not for you. But when you go over 10K you need a truck and a gooseneck will tow better than a bumper pull. Tractor trailers do not need safety chains, because they have air brakes. When it loses pressure the brakes will lock up. I have seen several trailers fall off the tractor that was towing it. If it has a light load the landing gear can survive. But if it is heavy it just breaks.
/ When to go gooseneck #29
My wifes excursion has exactly the same drivetrain as my trucks, but the leaf springs are much softer. Therefore I do not like towing with it, due to the perceived reduced capacity. I would feel much better about it with heavier springs and/or air bags.
/ When to go gooseneck #30
taht ex will have A codes in it. just swap in some b codes or c codes (if you want a dually ride). they bolt right in. you know that greg
I like my GN, i also like my bumper pull. Depending on what i am doing will determine what i take. GN do take some getting used to. especially the really tight track. there are some roads here i can not take my GN because the GN will track into the ditch. this is my biggest issue.
/ When to go gooseneck #31
They definitely shortcut more. :)
/ When to go gooseneck #32
Yeah, Terry, I know that... And hope to swap the springs now that I found a parts truck! Do hate to loose that smoother ride though... But look forward to clearing 35's!
/ When to go gooseneck #33
D.O.T. requirements for gooseneck hitches are the same as pull hitches (bumper hitch, etc, even pintle). D.O.T. makes no distinction between them.
/ When to go gooseneck #34
Wish I had a pic of my friend's EX with 38's on it but alas I do not. I'll see if he can send me a pic. It was insane. He's a short guy. How he got in it is beyond me. He sold it and now drives a sweet SD. I've got a pic of it somewhere. "Digging"......
/ When to go gooseneck #35
Air bags, best of both worlds. Put them on my 3/4t Ram and it makes a huge difference and once aired down rides like they aren't there. Mine rode so rough I didn't want to put stiffer springs.
I pull a 16ft dump bumper pull and it makes for a much easier ride since it's easy to get a higher tongue weight then expected.
/ When to go gooseneck #36
Thank you Rara Avis
Had an ex trucker with me this afternoon and asked him this question and he said, "I do not know."
KThompson
/ When to go gooseneck #37
Air brakes have nothing to do with safety chains on semi's. As mentioned before, it is the strength of the kingpin and properly adjusted fifth wheel jaws. If you ever watched Highway from **** when they were trying to disconnect a tractor and trailer in a bad way, that connection can be tough to seperate. Real life and not some TV show, that is exactly how it is.
If you saw a trailer seperate it was because as I said the fifth wheel jaws were not properly adjusted and/or the driver never crawled under the trailer and looked to see if it was properly secured. In addition to that, the driver still needs to test that connection.
FWIW, the tow dollys or jiffster's on a set of doubles do have safety chains that need to be connected to the lead pup. That is in addition to really heavy duty pintle hitches. The tow dolly of course has a fifth wheel so now the driver needs to crawl under two trailers. When I ran doubles, I did see them dropped on occasion. Some of the dolly configurations were shall we say seemed to be more prone (the ones with a high saddle for those of you whom have had the pleasure) so you had to be extra careful. I always did a figure eight in the lot before I ever pulled onto the main road. Trust me, making and breaking four sets a night gets old.
There are a couple of negatives with goosenecks. Though more of an issue with an older tow vehicle as in a lot less torque is that they do pull a little heavier. If you can, before you pull the trigger, hook the trailer up and see how it handles. Some combinations will cause "cab slap". That is a motion where as the seat back seems to be nudging you sometimes pretty roughly. On a dovetail or a beaver tail, watch the clearance between the rear frame and the road. Depending on your area of operation, you could be dragging a bit. Lastly, don't be jacking that trailer around anymore or faster than necessary. You can roll the tires right off of the rims.
/ When to go gooseneck #38
I can't think of a gooseneck trailer because my truck has a cap/shell on it. I need it to haul tools, etc for my work that have to stay dry. Therefore for me, just bumper pulls. However, my trailers are 7k and under. I am waiting on a 10k bumper pull to be built. Everyone has the own needs. Jon
/ When to go gooseneck #39
Like civilian I need a cap which makes a gooseneck not practical.
I pull a 14k dump on a somewhat regular basis and have a large dually tandem equipment trailer that gets used less regularly. I'm not sure why people say 10k is the max they'd bumper pull, I prefer gooseneck for heavier loads as they are more tolerant of less then ideal weight distribution but I wouldn't shy away from a properly connected and loaded BP even at close to 20k on a pickup.
/ When to go gooseneck #40
A trailer should not disconnect from the ball or king pin period. Yes the tractor trailers who lost the trailers was operator error. But even tow ball hitches should not disconnect IMG_0247.JPG
It's not the best pic, but the back of the truck is in the air. The truck is still connected trailer. They had to pick the truck up in the air pull the pin and slide the hitch out of the receiver. When there is pressure on any connection it is a bear to get it off and dangerous. I have yet to see a gooseneck come off, but I have seen bumper pulls and tractor trailers come off. Just my experience. In general the tractor trailer will stay connected when they roll. IMG_0179.JPG
213090 (A64276)
213090 (A64276)
213063 (A64276)
213063 (A64276)
Kubota L175 Tractor (A62613)
Kubota L175...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
UNUSED WOLVERINE TDB-11-84W-84" BUCKET (A64281)
UNUSED WOLVERINE...
2025 IREAS Grid-Shaped Rock Bucket Mini Excavator Attachment (A61572)
2025 IREAS...
