When to cut down trees?
/ When to cut down trees? #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
I have 6 or so trees I want to cut down to thin out my yard. They average 8 inch diameter at the base. Some bigger some smaller. I will use the wood for fire wood. When can I cut to minimize sap in the trees. I live in northwestern Louisiana. We are just getting Fall colors. It will be early Dec. before the leaves will be fully brown.
Harold
/ When to cut down trees? #2
Cut them now. You will get significantly more drying over the next month compared to waiting for lower sap levels.
Mike
/ When to cut down trees? #3
Remove a 12" band of bark completely around the tree now & cut next July. The leaves will draw a lot of moisture from the wood that the roots cannot replace. MikeD74T
/ When to cut down trees? #4
Harold
My Grandpa always said that the best time to cut a tree is anytime that you have a sharp saw...
case 370 glass door never installed (A61307)
case 370 glass...
METAL CRATE OF CASE IH COMBINE PARTS (A63290)
METAL CRATE OF...
2004 Quick Draw Coved Trailer (A64047)
2004 Quick Draw...
2020 International LT625 48" Sleeper (A62613)
2020 International...
Hydraulic Hoses (A62183)
Hydraulic Hoses...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
