Ballast Wheel Weights for BX2200
/ Wheel Weights for BX2200 #1
DannyD
Indiana
BX 23
I searched the forum under this phrase and found nothing on it. Can someone tell me where to get some weights for my 2200. After loading some dirt in a truck and without the tiller on the PTO, I noticed that the tractor was more than front heavy with a loaded bucket. This is fine with the bucket low, but when going over the side of a pickup, it can get a little tipsy.......and I dont even like carnival rides. I assume the dealer, but with all the wonderful knowledge of those on the boards, my guess is that someone has a great idea that works as well if not better.
thanks in advance.
/ Wheel Weights for BX2200 #2
You may want to look for used older weights from Garden Tractors etc. I re-used the weights that were on my Cub1811 when I bought it, and they were re-used from a Bolens tractor by the previous owner. I simply re-painted them Kubota Orange and they mounted up perfectly on my BX. Only had to replace the bolts with 1/2" longer ones.
Another option is a rear ballast box or weight. The attached picture shows mine with both the wheel weights and the rear ballast box. Kubota sells the box and it cost me about $165 when I purchased my unit.
Several people have made there own rear ballast by making a concrete form which is another option probably easier.
Another popular option is the EZ-Weights product or homemade versions of it using barbell weights bought at thrift stores for cheep.
There are many options, and some quite clever.
Good luck in your search.
/ Wheel Weights for BX2200 #3
The wheel weights will help, but you will get a better result with a weight box or heavy implement on the 3pt. Why? because you can get the weight farther back for a more stable and center of gravity. I have a weight that I madef from a galvanized wash tub filled with concrete, but often just put the backhoe on my BX22 when moving heavy loads in the bucket.
I actually thought of that and have a "reason" now for a carry all........build a box on it, put in some "weight" and it is alot "safer" to use the loader.........
Off to the TSC store.
/ Wheel Weights for BX2200 #5
Carry-all is great to have...I also bought the one from TSC. Do remember that it sticks way out the back of the machine "a lot". I left it on one time when I was "ploughing" snow and it limited my backing up abilty bit-time. As long as you have plenty of manuvering space, the carry-all will do the job with some stuff on it for additional weight, but pay attention to whether or not it interferes with where you can go when you need the weight to balance the FEL. Regardless...the price is right for the carry-all and it will be very useful to have many times!
/ Wheel Weights for BX2200 #6
I run both a weight box and loaded tires on my 2200. The only draw back with the box is that it sticks out back a bit and you have to remember that it is on when plowing....I left an orange stripe on the trim around my garage!
The box stays on all the time unless I am mowing.....no chance of that for a month or so....still snowing!
Have decided the carry all with some rocks (plenty of them here) will do what I want and I can use it for other things when the loader is not on. Thought about adding tire weight, but I want to change over to turfs for the grass cutting season and dont really need all that weight for that.
thanks all
/ Wheel Weights for BX2200 #8
I believe the Kubota manual suggests sand in the ballast box. I used to use rocks but realized if I tipped over those rocks would spill out and may hit me. I now use sand.
/ Wheel Weights for BX2200 #9
I also use sand. I bought bags of kids play sand. It was relatively cheap and I can put them in and out if needed for extra traction/ballast.
/ Wheel Weights for BX2200 #10
We have good cast weights from a company called Nohr State. They are heavier and of better quality than the Kubota weights. I'd sell ya a pair, but I am sure your not going to want to pay the shipping. Ask a local dealer and see what they can get you. A pair of ours is under $100.
/ Wheel Weights for BX2200 #11
I don't know if you may be looking for the bolt on adapter to uses regular barbell weights on your wheels. I keep looking at the device but don't actually have them yet. They are from eZweights http://www.ezweights.com/aboutez.php
/ Wheel Weights for BX2200 #13
Neil; How much do the weights that you mention weigh? I like the idea of wheel weights better than loaded tires because much of the time that I use the BX, I neither need or want the extra weight. I would be happy to buy the Kubota weights, except they only weigh 50 or so pounds, and there is no way to mount more than one on a tire. My dealer quoted me a price of around $50 for the Kubota weights.
Will
/ Wheel Weights for BX2200 #14
Will....... you can purchase the weights locally from almost any garden tractor dealer that sells a tractor that has a 24x12x12 rear wheel, such as JD, Bolens, Wheel Horse, etc. Look on e bay and other such places. I don't think that you are going to find much more than 50 pounds per weight, but you should try to avoid the shipping at all costs, because that is going to add a lot to your ultimate cost, but not add any value in the end. Do a search on e bay for garden tractor wheel weight and see what comes up. I just did one for Bolens wheel weight and found 4, but none in your area. They are out there, but you will just have to be patient or you will just have to pay more if you are in a rush. The choice is yours.
If you want the e-z weight system, here is an auction for them starting at $39.95 for just the brackets, without weights. to the auction...- Ends Apr-11-04 09:25:45 PDT
2006 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2017 Freightliner M2 106 Passenger Bus (A66736)
2017 Freightliner...
2023 CATERPILLAR 920 WHEEL LOADER (A65056)
2023 CATERPILLAR...
KAWASAKI 95ZIII Radiator (A68134)
KAWASAKI 95ZIII...
2015 INTERNATIONAL PROSTAR+ (A67714)
2015 INTERNATIONAL...
