Wheel Lug Bolt (Stud) for JD2210
   / Wheel Lug Bolt (Stud) for JD2210 #1
scsi2005
Maryland, USA
JD 2210, 60c deck, 260 Backhoe, 210 loader, JD 1023E 60 in. deck
High everyone.
A quick question.
I bought wheel extenders for my JD2210 tractor and would like to use longer wheel lugs to secure them to the axle. I can not find the metric values. Is it a 10x1.25 or a 10x1.50?
And does anyone know where I get them that are about 35-40 mm long. I can cut them shorter after I add a lock nut to bolt.
Thanks in advance.
Steve
   / Wheel Lug Bolt (Stud) for JD2210 #2
According to JD parts it's NOT a Metric bolt: P/N M144698.
It's 7/16-20 with an overall length of 1.4"
How long, overall, do you need?
The only longer from JD is P/N M177386 1.7" overall
Auto parts store might be able to supply longer.
   / Wheel Lug Bolt (Stud) for JD2210 #3
Try matching diameter and thread pitch to DORMAN products catalog..... They have literally hundreds of "wheel" products in both SAE and metric....
Dale
Thank you both for the help. I just thought everything had gone metric lately.
Thanks again.
Steve
Just some info for you Dale,
The JD2210 has 7/16" lug bolts and not metric. Its pretty hard searching for spacers to match with 7/16".
I bought a $275.00 set from Bora which said they would fit my tractor but they supplied me with 12mm bolts and the holes were to big for the 7/16" and I destroyed one side by using my 7/16" bolts..
I am working with them to get this corrected at this time.
Thanks again.
Steve
Steve
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
TOOLBOX (A50854)
TOOLBOX (A50854)
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2005 GROVE RT700E ROUGH TERRAIN CRANE (A50854)
2005 GROVE RT700E...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
