Wheel Lug Bolt (Stud) for JD2210
   / Wheel Lug Bolt (Stud) for JD2210 #1
scsi2005
Maryland, USA
JD 2210, 60c deck, 260 Backhoe, 210 loader, JD 1023E 60 in. deck
High everyone.
A quick question.
I bought wheel extenders for my JD2210 tractor and would like to use longer wheel lugs to secure them to the axle. I can not find the metric values. Is it a 10x1.25 or a 10x1.50?
And does anyone know where I get them that are about 35-40 mm long. I can cut them shorter after I add a lock nut to bolt.
Thanks in advance.
Steve
   / Wheel Lug Bolt (Stud) for JD2210 #2
According to JD parts it's NOT a Metric bolt: P/N M144698.
It's 7/16-20 with an overall length of 1.4"
How long, overall, do you need?
The only longer from JD is P/N M177386 1.7" overall
Auto parts store might be able to supply longer.
   / Wheel Lug Bolt (Stud) for JD2210 #3
Try matching diameter and thread pitch to DORMAN products catalog..... They have literally hundreds of "wheel" products in both SAE and metric....
Dale
Thank you both for the help. I just thought everything had gone metric lately.
Thanks again.
Steve
Just some info for you Dale,
The JD2210 has 7/16" lug bolts and not metric. Its pretty hard searching for spacers to match with 7/16".
I bought a $275.00 set from Bora which said they would fit my tractor but they supplied me with 12mm bolts and the holes were to big for the 7/16" and I destroyed one side by using my 7/16" bolts..
I am working with them to get this corrected at this time.
Thanks again.
Steve
Steve
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
