Rotary Cutter What's under that rotary cutter?
   / What's under that rotary cutter?
Re: What\'s under that rotary cutter?
<font color=blue>...( mine is a 472 )...</font color=blue>
Dick...
Did anyone ever tell you... you have excellent taste in implements.... /w3tcompact/icons/grin.gif
How long have you had yours...? They do offer the 472 with dual tail wheels...
My next upgrade will be the 672 or the Tree cutter… TCO-2615 … I figure by then I’ll have to upgrade the tractor as well… /w3tcompact/icons/wink.gif
   / What's under that rotary cutter? #12
If you have as much **** as you have tractor pictures you could rule the internet. /w3tcompact/icons/wink.gif
   / What's under that rotary cutter? #13
I think the underside of a rotary cutter is considered "Tractor ****" /w3tcompact/icons/wink.gif
   / What's under that rotary cutter? #14
John - I bought my Brown in July of 2000. At the time I looking for testimony. Didn't get any but decided to <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=owning&Number=10108&Search=true&Forum=All_Forums&Words=bought%20the%20brown%20rotary&Match=Entire%20Phrase&Searchpage=0&Limit=50&Old=allposts&Main=10108>buy it anyway because of its Bush Hog 286 similarity, but friendlier dealer. I like the mass of it.
Oh, and to allay any fears of blade metallurgy causing straightened ones to crack (pennwalk above) - they are dead soft at the pin end.
John & others, I appreciate the info. I am now 100% smarter /w3tcompact/icons/smile.gif
   / What's under that rotary cutter? #16
Bottom of John Deere MX7 rotary cutter... medium duty using 3" width blades...
{see attachment}
   / What's under that rotary cutter? #17
Bottom of John Deere 513 rotary cutter... (regular duty using 3" wide blades)
{see attachment}
Notice 1" thick steel blade holder {missing optional stump jumper pan}
On the heftier rotary cutters, these are huge "flywheels" up to 40" diameter @ 1 1/4" thick weighing as much as 625lbs. alone...
   / What's under that rotary cutter? #18
Geez... the JD rotary cutters look kinda cheesy compared to some of the other brands. /w3tcompact/icons/blush.gif
Glad I went with a Woods.... /w3tcompact/icons/smile.gif
Terry
   / What's under that rotary cutter? #19
Thats an understatement./w3tcompact/icons/sad.gif
How do you change a blade?
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A60460)
2012 Vermeer...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
