Whats the differences between 3R and 3E?
   / Whats the differences between 3R and 3E? #21
Congratulations on your new tractor, you'll enjoy it.
   / Whats the differences between 3R and 3E? #22
R was wise choice. Anyone who buys a green tractor with a suffix "E" Must really like Green and yellow paint.
   / Whats the differences between 3R and 3E? #23
No, we just like simple and reliable. 3 years and no issues. Plus, tractor, loader, brush hog and rear blade for $19k delivered was a no brainer.
   / Whats the differences between 3R and 3E? #24
Yes Sir!
   / Whats the differences between 3R and 3E? #25
and, in a week a grapple that is on order), will be making my life so much easier than it used to be.
I'd like to know what grapple you ordered, has it been put to use, and what do you think of it? Thanks!
Mine is from Deere (aka Frontier - their implement division). I forget the model number, but it's right outside the door. Well, no model number on it. But it measures 61" from left to right. It comes on and off the FEL in about 3 minutes. Amazingly easy.. Just don't forget to undo the extra hydro lines for the top jaw.
Last weekend, I cleared a bunc of logs, stumps and branches, piled them into a huge brush pile and burned them all. What would have taken me all weekend on 8N and a whole bunch of hand work took 3 hrs with the grapple and I got of the tractor only two times to pull stuff away from a fence corner where I could get at it better. If I had any skills with this tractor and implement, it might have taken only half that long. There is no doubt in my mind that the grapple will be the most-used implement on my tractor and I can't figure out how I survived without it. One neat trick I did twice was to reach over a low fence and simply pluck 12" ash stumps that were on the other side. The roots were rotted, so they weren't that hard to pull out, but to simply reach out, grab, and lift over the fence was super easy and relative to the alternative (taking down the fence and dragging them out), a real life and time saver.
If I have two criticisms of it, they would be 1. The lower tines are not really long. I see some units that are more "L" shaped, as if the lower tines were like a forklift almost. Well, these are shorter. It doesn't take as big of a bite of a stack of small limbs as it would if the lower tines were longer. But then, I don't know how much I need this and it still grabs plenty.
2. The upper lid doesn't open as far as I wish it would. But then I didn't really find that limited me. I just thought it should open further.
Right now, I'm chilling, drinking a beer, and recovering from mixing 800+# of concrete for my soon-to-be ballast box that will allow me to grab even larger logs than I have so far. I'm really looking forward to using the heck out of this tool. I think it will be just about perfect for my purposes (logging hardwoods and clearing trees).
   / Whats the differences between 3R and 3E? #27
I've seen lots of grapples from 3rd party dealers, and have wasted lots of time looking at videos on-line. I first looked at a RatchetRake, then a Wicked grapple from EverythingAttachments. I think I'll be using a grapple a LOT with the tasks I have in mind for my (eventual) machine. Thanks for the input!
I wanted something simple plus I got a decent discount on it from JD along with the tractor and a posthole digger and the FEL/bucket of course.
I like the looks of on of the longer-tined EA Wicked grapples. Maybe I would like that better. I would solve the lower tine issue, but then it would be harder moving around in the timber and I do a lot of that. There is no end to the tradeoffs, so, I'm good with this one. One thing is for certain, it is **** for stout!.
I looked at all those videos and realized that I needed the grapple more than anything else even though I didn't realize such things even existed when I started tractor shopping. I was thinking just the bucket would be all I really needed. I was clueless.
   / Whats the differences between 3R and 3E? #29
E series has an aluminum block engine & is a basic model.
I believe the R is the same. In the end, I bought the R and I'm darn happy with it. Going from an early 8N to this is like crawling vs running.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
John Deere 4020 Tractor (A50514)
John Deere 4020...
