Whats the differences between 3R and 3E?
/ Whats the differences between 3R and 3E? #21
Congratulations on your new tractor, you'll enjoy it.
/ Whats the differences between 3R and 3E? #22
R was wise choice. Anyone who buys a green tractor with a suffix "E" Must really like Green and yellow paint.
/ Whats the differences between 3R and 3E? #23
No, we just like simple and reliable. 3 years and no issues. Plus, tractor, loader, brush hog and rear blade for $19k delivered was a no brainer.
/ Whats the differences between 3R and 3E? #24
Yes Sir!
Mine is from Deere (aka Frontier - their implement division). I forget the model number, but it's right outside the door. Well, no model number on it. But it measures 61" from left to right. It comes on and off the FEL in about 3 minutes. Amazingly easy.. Just don't forget to undo the extra hydro lines for the top jaw.
Last weekend, I cleared a bunc of logs, stumps and branches, piled them into a huge brush pile and burned them all. What would have taken me all weekend on 8N and a whole bunch of hand work took 3 hrs with the grapple and I got of the tractor only two times to pull stuff away from a fence corner where I could get at it better. If I had any skills with this tractor and implement, it might have taken only half that long. There is no doubt in my mind that the grapple will be the most-used implement on my tractor and I can't figure out how I survived without it. One neat trick I did twice was to reach over a low fence and simply pluck 12" ash stumps that were on the other side. The roots were rotted, so they weren't that hard to pull out, but to simply reach out, grab, and lift over the fence was super easy and relative to the alternative (taking down the fence and dragging them out), a real life and time saver.
If I have two criticisms of it, they would be 1. The lower tines are not really long. I see some units that are more "L" shaped, as if the lower tines were like a forklift almost. Well, these are shorter. It doesn't take as big of a bite of a stack of small limbs as it would if the lower tines were longer. But then, I don't know how much I need this and it still grabs plenty.
2. The upper lid doesn't open as far as I wish it would. But then I didn't really find that limited me. I just thought it should open further.
Right now, I'm chilling, drinking a beer, and recovering from mixing 800+# of concrete for my soon-to-be ballast box that will allow me to grab even larger logs than I have so far. I'm really looking forward to using the heck out of this tool. I think it will be just about perfect for my purposes (logging hardwoods and clearing trees).
/ Whats the differences between 3R and 3E? #27
I've seen lots of grapples from 3rd party dealers, and have wasted lots of time looking at videos on-line. I first looked at a RatchetRake, then a Wicked grapple from EverythingAttachments. I think I'll be using a grapple a LOT with the tasks I have in mind for my (eventual) machine. Thanks for the input!
I wanted something simple plus I got a decent discount on it from JD along with the tractor and a posthole digger and the FEL/bucket of course.
I like the looks of on of the longer-tined EA Wicked grapples. Maybe I would like that better. I would solve the lower tine issue, but then it would be harder moving around in the timber and I do a lot of that. There is no end to the tradeoffs, so, I'm good with this one. One thing is for certain, it is **** for stout!.
I looked at all those videos and realized that I needed the grapple more than anything else even though I didn't realize such things even existed when I started tractor shopping. I was thinking just the bucket would be all I really needed. I was clueless.
/ Whats the differences between 3R and 3E? #29
E series has an aluminum block engine & is a basic model.
I believe the R is the same. In the end, I bought the R and I'm darn happy with it. Going from an early 8N to this is like crawling vs running.
/ Whats the differences between 3R and 3E? #32
Al con rod in a diesel would be done in a day or less.
/ Whats the differences between 3R and 3E? #33
It is the Rear differential/Axel Housing that is aluminum. It is functional, but lighter, and potentially more susceptible to failure (3 point attachment points breaking for example).
/ Whats the differences between 3R and 3E? #34
I managed to break aluminum axle housings on a Deere (had a major backhoe problem)
Fortunately, I was able to change them along side a buddy who had the same problem - his were broken too,
The good thing for me was the replacement Deere parts were a lot less than his Kubota ones.
And, yes, I would have been the first one to say that those cast iron ones would gold up better.
/ Whats the differences between 3R and 3E? #35
But, as to reliability on a Yanmar engine. There is no need to defend them. They are legendary.
Not that Kubota's aren't.
/ Whats the differences between 3R and 3E? #36
True that. I hope Yanmar does well with its stand alone USA product launch. They make good stuff (and have an innovative new transmission). They will need to expand their dealer network and price aggresively early on to show they mean business. That said, they know how to build CUTs, and have a strong pedigree.
iDrive TDS-2010H...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2018 John Deere 310L EP Backhoe (A63109)
2018 John Deere...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2006 Chevrolet Silverado 1500 Pickup (A63116)
2006 Chevrolet...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
