What's happened here?
/ What's happened here? #21
For some reason, the wife acts as if she could care less about my hydraulic problems. :D
Who'da thought..............:confused::confused::rolleyes::rolleyes:
I'm impressed that you have decided to give this B2400 a new lease on life,but you realize you are out of your mind........ right?;)
Ducttape, whatever do you mean?:)
I'm not out of my mind, I'm just determined. I go crazy(out of my mind) if I don't have a project to work on. Usually it involves something with an International Harvester badge on it (Scouts), but Kubota is just as good.
I've been having withdrawl symptoms since I sold my B21 contractors backhoe a couple of years ago. I had it for almost 10 years and that was one heck of a machine.I was getting out of general contracting and thought I didn't need it any more, boy was I wrong. You never realize how handy a tractor is till you don't have one.
I only paid $800.00 for the B2400HD with the 60" belly mower and the mount and control valve for the FEL,so I figured I couldn't go wrong.(working on getting the loader arms and bucket back from the guy that bought it from the town. He paid $647 for it and wants $1,800 now.:mad:) .
The town garage had a bunch of parts for the thing too. I'll have about $3000 (less the FEL)in the tractor when I'm done, including the purchase price, and it should be as good as new when I'm done.
It's funny though, my wife said I was crazy when I pulled up with the tractor. She has since come around when she saw how well it mowed.
BTW, I tore the power steering down last night and other than a couple worn O-rings which I ordered, everything was good. I think the problem was when I put it back together after replacing the top seal on the shaft, I overtightened the plug sleeve, causing the needle bearings to be too tight and binding. I probably could have just lossened it, and all would have been well in hydraulic land.
I guess I'll find out about next wednesday when the parts come in.
Wish me luck.
Brad
/ What's happened here? #23
if it uses an orbital valve on the ps and there was rubber circulating.. you will have quite a job picking pieces out and cleaning orifi with a wire..
if it is a different style.. you may still have rubber in valves.. and or a plugged filter..
soundguy
soundguy
Luckily, the filter on the pickup for the pump did it's job perfectly. When I tore the power steering unit apart, there were no sign of the rubber bits I found in the reservoir.
/ What's happened here? #25
dodged a bullet on that one.
soundguy
All right guys, I need some suggestions again before I set this tractor on fire myself. ;)
I put the power steering unit back together with all new seals and o-rings and it works a little, but I still have the whining and vibration from the pump.
I did a crackle test (pretty cool) and I definately have air in the hydraulic fluid which i hope is the cause of the weak power steering. The TPH and transmission are still working fine.
I've got two questions for y'all.
Is there any way to get the air out of the fluid?I've already drained it out and am debating replacing it, although I hate to do that beacuse it only has about 20 minutes run time on it and super UDT is expensive stuff.
My other question is, besides a leak in the suction line which I have ruled out, how else could air have gotten in the fluid? I was thinking maybe the suction screen being clogged might have had something to do with it.??
I'm about to get agravated and any suggestions or thoughts would be highly appreciated.
Thanks
/ What's happened here? #27
If it is air, it should rise to the surface over night. If you are seeing air all the time, especially when running, then you are sucking in air from somewhere, the other way for air to be in there is a large difference in pressure say between one side of an opening. and the other side. I believe when pressure is being relieved, that air could be generated. and that is the sound you hear.
/ What's happened here? #28
http://atl.grc.nasa.gov/Documents/PDF/D2.pdf
/ What's happened here? #29
I agree.. if it is staying air entrained.. or foaming, it's cavitation.. or has a suction side leak.. ( or both).
soundguy
/ What's happened here? #30
Put it on a stove and bring it up to 180 or so and cook the water out. Might be able to tell by how much volumn you lose.
/ What's happened here? #31
Have you had the fluid properly warmed up and circulated. Leaving the fill cap a little loose or open but protected should allow any air to escape after all the hydraulics and steering have been used a little.:confused:
Or does your fill cap also contain a vent?:confused:
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
New/Unused Landhonor LHR-CSC10 Squeeze Chute (A65583)
New/Unused...
John Deere 490E Excavator (A62679)
John Deere 490E...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Pivot Pipe (A64127)
Pivot Pipe (A64127)
