What valve for TNT?
/ What valve for TNT? #1
Buty
Canton, GA
Kubota L3200
Planning for my next project but I did not have any rear remotes. First question, What type valve would be best for a TNT?
/ What valve for TNT? #2
You will want at least two sets of remotes for top and tilt both, unless you want to use a diverter valve, then you can get away with a single set of remotes on the rear.
/ What valve for TNT? #3
I typically recommend that a person get at least one of the valves with the float function, preferably both. And then as long as you are doing this, you might as well get 3 control valves, not that much more money and once you start using hydraulics, you end up wanting more functions to be hydraulic actuated.
Are you sourcing items yourself, or are you going with the Kubota set?
I have a 3 valve set, 2 with float function for $890. That is everything you need to have this operational except the actual valve mounting bracket. ;)
Here is a link to a guy that just finished doing his own setup on his L3800. Very Very nice install. :thumbsup:
Thanks for the replies guys. Looks like this project may be beyond my skills so for now, it's more reading.
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
