Disc Harrow What Type of Plow to Use/Own
   / What Type of Plow to Use/Own
That's an idea - big farmer. I've got a few options for water. Dont have gutter system set up on any of our buildings yet, but have the equipment. We also have an old circular cement well that holds water. Currently I am using a water pump to pump water from the well into water tanks & water our garden from there. My plan is to buy some more water tanks & a smaller trailer & have a mobile water station to spray w/my pump. Once have gutters in place on shop & house, will probably rig a gravity drip system, or add a smaller 12v pump if not enough pressure.
Any advice you could add on watering, I am all ears....
   / What Type of Plow to Use/Own #12
if your 500 ft from the Brazos, you should have water about 30 feet down. A well would probably be a reasonable expense around $3k.
Its hard to collect water for a large garden in central Texas. I know my place just down I-35 hasn't seen rain since the end of May.
   / What Type of Plow to Use/Own #13
I want to offer all of my info to get the best ideas bc so far, TBN has been great helping a new tractor owner!
I live outside of Waco, TX, about 800 yds from the Brazos river, as the crow flies. I have great river bottom soil.
I've got an 1950 8N that my dad rebuilt that I just used with a shredder for the 1st time last night & cut down some of my fields. I do also own a 2009 Kioti 40 hp, but I really just want to use with the bucket with this tractor, & will rent a post hole digger sporadically when I need, don't really want to remove the bucket to use other attachments.
My plan is to shred & plow with the 8N. I have about 1 acre I am going to devote to planting some kind of crops. Haven't decided if I just want to make a food plot for deer, or maybe harvest some crops - corn, potatoes, onions, etc.
I am asking for help/suggestions with the type of plow that would be best. Not sure if need to get disk plow or a row bedder? I think there is a chisel plow as well? What would be some of the different criteria I would need to look for between the different types of plows?
I appreciate all the help & suggestions here, this place has been wonderful!
Chris
The disc plow in the link below is most likely what would work best for you. A roto tiller on the N tractor is not going to work well at all. Ken Sweet
Used Dearborn 2 Disc Turning Plow 3 PT Hook We SHIP Fast and Cheap | eBay
   / What Type of Plow to Use/Own #14
8Ns are cute tractors. Pretty good at pulling floats on a parade and hauling wagons and trailers around for firewood and odd jobs. They're alright at pulling a plow or disc also. Why anyone with a modern tractor would even begin to consider putting a bush hog or tiller the back of one is totally beyond me.
Your 40 Kioti is much much better suited these tasks. It has way more HP and lower gears. I've run bush hogs and tillers behind our 2 (now down to 1) 8Ns, for years. Since we got our Kubota I've never considered hooking anything up to the PTO of the N.
Go bush hog for an hour with the Ford, then hook it up to the Kioti and see what you think.
In regards to your question though, a rototiller would be the handiest tool to own for tilling a one acre field.
   / What Type of Plow to Use/Own #15
Your 40 Kioti is much much better suited these tasks. It has way more HP and lower gears. I've run bush hogs and tillers behind our 2 (now down to 1) 8Ns, for years. Since we got our Kubota I've never considered hooking anything up to the PTO of the N. Why anyone with a modern tractor would even begin to consider putting a bush hog or tiller the back of one is beyond me.
~~~ X 2 ~~~
The Kioti is SAFER to operate, too. There is not much shielding from moving parts on the original 9N/2N/8N Fords.
   / What Type of Plow to Use/Own #16
Lots of mesquites.... Now that I have grass cut, I am gong to spend some time pulling/cutting out the bigger mesquites I couldnt cut with shredder. I prob have around 30 to get out of the ground now, none of them bigger than 2" in diameter.
I have dealt with mesquites a lot. You may want to try just pushing them over with your loader. Start about 2 to 3 foot high. Most of mine will come out with the root ball just pushing them with my tractor. You may want to load your tires for more traction.
It sure makes my life easier.
To answer your question... You have received much good advice already. I have all of the mentioned implements and I use to do a lot with the tiller, but I have found that it over works the soil over a period of time. It is hard for me to give you advice since you will be buying implements to use. I hate to spend my hard earned money and I am not comfortable spending other peoples money.
So, my suggestion is; read everyones input and reread it again, take your time before deciding what to do. Unless you have lots of money, lots of time to play, and find out what works for you, and your soil and your tractor.
   / What Type of Plow to Use/Own #17
One acre; rototiller would meet all your needs. Use the kioti.
Tradition farm implements just are not suited to small plots. Very awkward to use.
   / What Type of Plow to Use/Own #18
I have a two bottom ford 102 series rollover plow that would work. I'm only a few hundred miles from you in Levelland Texas. Its the one in my signature
   / What Type of Plow to Use/Own #19
I used a $150 subsoiler to "plow" then a tiller behind my 32hp L3200hst. Worked great. Use a tiller under an few acres, not a disc.
   / What Type of Plow to Use/Own #20
That would be my suggestion too. Break it up deep then rotovate or rototill after. You need some weight on the tractor to get a grip when sub soiling. It probably only needs doing every couple of years depending on how compressed the soil gets.
Forklift (A59228)
Forklift (A59228)
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Wolverine Quick Attach Screening Bucket (A59814)
Wolverine Quick...
2010 Honda Accord Sedan (A59231)
2010 Honda Accord...
