What tool do I need?
/ What tool do I need? #1
JasonL
Pendleton, IN
JD 4110
I am cleaning out a wooded area on my property. It had a lot of small bushes and trees that I cut with a chainsaw before I had my tractor. Now I am removing these roots/stumps with a rear blade and/or FEL. This is leaving quite a mess of debris. Would a landscape rake be the answer to gathering these up? I am concerned about what happens if it catches a root/stump I missed. Also I probably will want a box blade also, but don't know if I can get both now. Any ideas?
Thanks- Jason
/ What tool do I need? #2
Jason,
Try a york rake, but use the adjustment in the 3pt hitch to keep it up off the ground a few inches during the first pass. Then after you've raked off the heaviest debris, go back over it with the rake lowered all the way down. If you go slow and pay close attention while you rake, it shouldn't matter if the rake catches a stump that you may have missed, you'll be able to stop before causing any real damage. Good luck!
Teach
/ What tool do I need? #3
You've been given pretty good advice, and I'll go just a bit further with an explanation. If you keep the tines up just a bit, what you grab will do a good job of grabbing more and then you won't need to have the tines on the ground that much until you go back for the final clean up.
Keep your eye on the rake's progress, however, because when your tractor's front end goes down in a depression it will lift the rake up even more, dropping your load. You can avoid a lot of that by anticipating it happening, and lowering the rake a bit for just when you go through the depression and then lift it up a bit again after you level out.
After doing it a few times, you'll see what I mean.
If you lengthen the top link, you'll have the tines angled more toward the back, and not aggressively digging into the ground which would allow you to keep the tines pretty close to the ground, and small stumps should not be a real problem as the tines will "skip" over them without much fanfare.
I use a landscape rake this way a lot, and am happy to have it. Of course, the boxblade is probably one of my most used, and versatile attachments, and you'll be glad to have one of those as well.
John
/ What tool do I need? #4
JasonL-
I have similar work to be done on my property and am very interested in your progress. Could you please post before and after pics?
Thanks,
Bonehead
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2008 MACK GRANITE KILL TRUCK AND TRAILER (A63569)
2008 MACK GRANITE...
