What To Use For Front Shields ON Brush Hogs?
   / What To Use For Front Shields ON Brush Hogs?
Agree with the conveyor belt suggestions. Regular neoprene is not nearly tough enough.
I'm agreeing on this. The neoprene was cheap and available so it was a starting point.
   / What To Use For Front Shields ON Brush Hogs? #13
But you can find "conveyor belt" in 1/8 thickness.
There are thousands of different kind of belting . Yes finding a 1/8" thick is not a problem . Most rubber Belts are cheaper than plain Sheet rubber and are much stronger . I could answer any belting Questions anyone has just let me know . Another source is a farmer replacing his round baler belts .
   / What To Use For Front Shields ON Brush Hogs? #14
Scroll down this list and you will find some distributors
This one should work : IBT industrial solutions
City / ZipLocation NameLocation TypeContactRFI
OklahomaMuskogee, OK 74401 Ibt918-683-0900
Oklahoma City, OK 73106 Ibt405-236-2416
Pryor, OK 74361 Ibt918-825-8215
Tulsa, OK 74116 Ibt918-438-8100
   / What To Use For Front Shields ON Brush Hogs? #15
Use a chain skirt both on the front and back of the mower and you'll never look back.
   / What To Use For Front Shields ON Brush Hogs? #17
I used an old tire. I cut it so it would be as long as possible, then mounted it with some bolts so the curve of the tire catches all debris. It works great!!!
The OP was trying to keep dust in check.
And chain skirts are big dollars!
Chains are definitely safe though and I do have chains on the rear of this one.
   / What To Use For Front Shields ON Brush Hogs? #19
I have a few brush hogs which do not have the original shields on the front. To replace them can be a bit pricey for some.
I have purchased a roll of 1/8 inch thick solid neoprene (10ft X 12 inch) should be able to get 4 to 6 out of the roll depending on size. I'm going to try this out and see how it works out.
What do you use to make new shields from?
Obviously chains are the best
   / What To Use For Front Shields ON Brush Hogs? #20
I'm thinking about using the sidewall off a truck tire.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58216)
2008 TEXAS BRAGG...
2259 (A58376)
2259 (A58376)
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
