What to buy???
/ What to buy??? #1
Jpsrvcs1
Central, NJ
I'm new to this, but I'm gonna give it a try. I'm looking to purchase a compact tractor for my small landscaping company. Priority #1 is a loader for mulch, stone, and to add forks to remove pallets of stone from the back of the truck. I also do a fair amount of sod jobs, and it would be nice to move snow piles around after the storm is done. so as I've looked around for about 3 weeks now I've found what seems to be my two best options for the amount I want to spend. A cub Cadet 2072 but I have to buy the loader, all said and done a total of about $,500. Or a Jinma 220 with a total of about $8,000 but it's brand new and I can finance it. Before I even get into other attachments, what do you guys think is the best move. I'm open to other suggestions too, thank you
Steve
/ What to buy??? #2
Steve
That CC 2072 is a garden tractor, not a CUT. Doesn't sound to me what you want to move pallets of stone.
The JM 220 is a SCUT (22 hp engine) that might work for you depending on the weight of those pallets of stone. My Kubota B7510HST (21 hp engine) had a loader that could lift about 800 lb at the bucket pivots. With a pallet of stone on bucket forks, that limit probably would drop below 700 lb.
Can't really give good advice without more info on the weight you want that loader to handle.
I'd look for a pre-owned skid steer with a bucket and forks and possibly with removable tracks if you're concerned about messing up your customers' lawns.
/ What to buy??? #3
Lifting palletts of stone will require at least a small ag utility tractor 45 plus HP. A skid steer would be the answer there.
/ What to buy??? #4
I think you need a skid loader, like a Bobcat or similar. Pallets of stone are very heavy (1000 - 3000 lbs) and most small tractors would not have the lift to pick them up. You could put forks on the 3PH and get more lift out of a small tractor.
I think both models you are considering would be inferior for the kind of work you are doing. If you must have a tractor, consider a Kioti CK20 - small but powerful loader, and heavy and enough for the digging and lifting. If your budget is in the $7K range or so, then look for a good used machine.
A skidsteer is still the best option. It is what most landscapers are using for excavation etc.
/ What to buy??? #5
Keep lif specs in mind.. a full wet pallet of sod can weagh over 3000#.. many scut and small cut loaders aren't rated for that..
soundguy
Steve
/ What to buy??? #6
The guys are right. You would need a pretty big tractor to lift stuff like that with a FEL. A skid steer would be better.
/ What to buy??? #8
I'll throw out a couple of ideas. The others are correct, a SCUT will not pick up a pallet with any weight. What it can do is put the bucket in the back of a pick up or on a trailer within inches of a pallet. I put quite a few landscape blocks in to make a wall this way. I put the bucket in the back of my truck and unloaded the blocks into the bucket, just a foot away or so. Then I put the bucket within a foot of where I unloaded it.
The reason I bring that idea up is that a used skid steer is some pretty serious money, much more than a used small tractor or even a new one. A small tractor is very versitle, it just won't lift much over 500lbs at at time. Parked next to a serious machine, a small tractor looks like a toy. Parked next to a wheel barrow and a shovel, it starts looking pretty good.
/ What to buy???
Thank you all for your help. I understand I have to give up on the removing a pallet of stone from the back of the truck. It's OK, like I said mostly it will be used for mulch, that is the material i end up using the most, and stone as a 2nd. Either way it will still be better than having to shovel any of it into a wheel barrow or our dump cart.
/ What to buy??? #10
Yep.. -any- loader beats a shovel and wheel barrow!
soundguy
/ What to buy??? #11
Check ebay for the AVS RC50 used (or machinery trader). Last year I was thinking about a rc30, rc50, Kubota b26/3030 or a B2920. I found some good deal and packages on the rc50. I started to avoid the rc30 because of its nonstandard bucket connection. I found a used b2630 for a good deal, so I bought it. The only two things about rc50 I didn't like was alittle to wide (plow a lot of side walks) and a little to heavy for my 1/2ton truck.
I mostly plow snow and fork work with mine. I'm happy, but some days I wish I had the rc50.
Good luck.
/ What to buy??? #12
Oh. One other thing about the rc50. It is a tracked skid steer with very low ground pressure. Good for finished lawns. Just don't turn sharp!
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSENECK TRAILER (A59909)
2022 BIG TEX...
2015 FORD F-350 XL SUPER DUTY 12' BOX TRUCK (A62130)
2015 FORD F-350 XL...
2015 Ford F750 Dump Truck (A64047)
2015 Ford F750...
