What tires are best suited for me
   / What tires are best suited for me #11
I stand corrected on concern about rim size vs tire style
lou thanks for posting that information.
   / What tires are best suited for me #12
Turfs with single cross link chains. Good traction and not hard on turf unless the wheels spin. (wet uphills)
If that’s the only reason have you priced new tires and zero turn mower’s? You could easily be in the 3k range for two rear tires for that tractor.
I believe another consideration is the rim size. Not 100% positive but I believe R4 & turf require a different rim vs R1 ag. Some R1 ag have less aggressive lug patterns than others. Not sure if available in your size or cost but radial R1 have larger foot print and may be less aggressive also. Never ran radials on this small of tractor so not sure.
Thanks for the help
I’ll look into those
The tractors like mine that have turfs have much wider rims I do believe
   / What tires are best suited for me #16
I've got that set up on the two smaller tractors (25 and 18 HP) Work great summer and winter. Weight goes on the back in winter ;-)
   / What tires are best suited for me #17
I suspect that unless the OP is replacing wheels, the choice will be made by what tires will fit on the existing wheels.
Yeah most of the turf tires are wider than what the rim can do
   / What tires are best suited for me #19
Nothing wrong with having an alternet set of mounted tires handy.
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2007 MACK CHN DAY CAB (A56129)
2007 MACK CHN DAY...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
KUBOTA ZD1211 (A53084)
