What tires are best suited for me
   / What tires are best suited for me #11
I stand corrected on concern about rim size vs tire style
lou thanks for posting that information.
   / What tires are best suited for me #12
Turfs with single cross link chains. Good traction and not hard on turf unless the wheels spin. (wet uphills)
If that’s the only reason have you priced new tires and zero turn mower’s? You could easily be in the 3k range for two rear tires for that tractor.
I believe another consideration is the rim size. Not 100% positive but I believe R4 & turf require a different rim vs R1 ag. Some R1 ag have less aggressive lug patterns than others. Not sure if available in your size or cost but radial R1 have larger foot print and may be less aggressive also. Never ran radials on this small of tractor so not sure.
Thanks for the help
I’ll look into those
The tractors like mine that have turfs have much wider rims I do believe
   / What tires are best suited for me #16
I've got that set up on the two smaller tractors (25 and 18 HP) Work great summer and winter. Weight goes on the back in winter ;-)
   / What tires are best suited for me #17
I suspect that unless the OP is replacing wheels, the choice will be made by what tires will fit on the existing wheels.
Yeah most of the turf tires are wider than what the rim can do
   / What tires are best suited for me #19
Nothing wrong with having an alternet set of mounted tires handy.
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
SKID MOUNTED WATER PUMP (A55745)
SKID MOUNTED WATER...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
Landoll Lowboy Trailer (A55302)
Landoll Lowboy...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2016 FREIGHTLINER...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
