What tires are best suited for me
   / What tires are best suited for me #11
I stand corrected on concern about rim size vs tire style
lou thanks for posting that information.
   / What tires are best suited for me #12
Turfs with single cross link chains. Good traction and not hard on turf unless the wheels spin. (wet uphills)
If that’s the only reason have you priced new tires and zero turn mower’s? You could easily be in the 3k range for two rear tires for that tractor.
I believe another consideration is the rim size. Not 100% positive but I believe R4 & turf require a different rim vs R1 ag. Some R1 ag have less aggressive lug patterns than others. Not sure if available in your size or cost but radial R1 have larger foot print and may be less aggressive also. Never ran radials on this small of tractor so not sure.
Thanks for the help
I’ll look into those
The tractors like mine that have turfs have much wider rims I do believe
   / What tires are best suited for me #16
I've got that set up on the two smaller tractors (25 and 18 HP) Work great summer and winter. Weight goes on the back in winter ;-)
   / What tires are best suited for me #17
I suspect that unless the OP is replacing wheels, the choice will be made by what tires will fit on the existing wheels.
Yeah most of the turf tires are wider than what the rim can do
   / What tires are best suited for me #19
Nothing wrong with having an alternet set of mounted tires handy.
2006 INTERNATIONAL 9400I DAYCAB (A55745)
2006 INTERNATIONAL...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
BRADCO 42" MINI HYD TILLER (A52706)
BRADCO 42" MINI...
