what the world really need
/ what the world really need #1
howardx
A COMFORTABLE TRACTOR/MOWER!!!
I live in a small ranchette style neighborhood where i finish mow about 3 acres of what i would call "rough yard". I use a cub cadet with a 54" deck,about 10 yrs old, and i got to say "man is it rough on my fat city body!". Does anyone build a tractor with suspension? The only thing iv'e heard of is a ferris mower, but i would prefer the added utility of a tractor. Thanks for letting me vent.
howard
/ what the world really need #2
My New Holland TC25D (D = Deluxe) has a suspension seat that's adjustable for weight. I imagine many tractor manufacturers have deluxe models with similar seats. I know aftermarket suspension seats are available as well.
/ what the world really need #3
Seems like a suspension seat upgrade and perhaps a good roller to smooth your lawn is what you really need. Roll it while it's wet and soft in the spring and you'll be surprised at how much smoother it will be.
/ what the world really need #4
If your tractor has a tilt up seat, I saw a post on lawn and garden equip. forum (I think) that used a cheap wheel barrow sized tire with tube (minus the rim) inserted under seat to give some spring/cushion. Just adjust air pressure to your liking....air ride seat for tractor on the cheap.
/ what the world really need #5
Kioti puts suspension seats on all of there newer models, you don't have to buy a "deluxe" model or pay more for it :D . It took me a while to find the exact settings for my weight and terrain, but it is a very smooth ride. Even over my rough rocky terrain. There are adjustments for seat height, spring preload and rebound, and lateral position. You do loose the ability to flip the seat up though.
/ what the world really need #6
My NH 7610s has a spring-ride suspension seat.. nice and comfy thick 4" foam. My ford 5000 has nearly same seat with arm rests too.. I find them to be much easier than riding a rider lawnmower.. or my yerfdog CUV farm vehicle..
Soundguy
/ what the world really need #7
Rural King has suspension seats on sale for $69.00. Might be worth a look.
/ what the world really need #8
I test drove a Ferris ZTR but even with the suspension set up to ride the softest over rough terrain it was awful at best.
I added a really nice suspension seat base to my CK20, and it helped but was still pretty bad.
The TC33D I just got seems to have the problem tackled with its suspension seat.
It would be difficult to get a suspension seat or base that had enough travel to make a difference and not have you sitting a foot higher than your current seat.:)
/ what the world really need #9
As far as riding mowers go, the only thing I know that can help the ride is to roll the lawn. Take out bumps, ride gets better. Sounds like some of these CUTS have some pretty nice seats though.
/ what the world really need #10
The seat does fold on Kioti CK25's and CK30's, even with suspension.
Thanks everyone. My cub does have two coiled springs under the seat,so i don't know how much better i could do with the seat.Rolling my yard sounds like a great idea. I'll definitely check into that. thanks again for all the suggestions.
howard
/ what the world really need #12
Check your tire pressure -- you shouldn't have much pressure, maybe 10 lb or so. Many people fill them to car like levels and wonder why the ride is rough. I run 9 lb in the rears of my DX29, about 11 on my mower.
/ what the world really need #13
yep, you see that a lot. Little known fact here. It's volume of air, not pressure that holds up your vehicle. So that's why a big balloon tire on a flotation truck only has 3 or 4 lbs of tire pressure. My ATVs run on 3lbs. My offroad Jeeps with 37"x12.5" tires wheel on 4lbs. Properly inflated your tractor front tire may require more pressure than the rear tire for the same reason. :)
/ what the world really need #14
I have heard that aeration is a good way to smooth out bumps in your yard long term. The lumps get plugged deeper than the dips and the cores tend to accumulate in the dips. After several passes of aeration, things should get pretty smooth.
Rolling tends to compact things, so it may be smooth, but the grass will not be as lush.
Matbe combine the two. Aerate to loosen things up and roll it flat and then aerate again.
- Rick
/ what the world really need #15
I added two springs to the rear of my flip up seat on the Ford 1100. It didn't have much travel, and it helped a little.
The JD has a suspension seat, so I haven't had to worry about it.
David from jax
/ what the world really need #16
Move to a place with 10+ acres and give up the idea of mowing forever...
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
KUBOTA MOTOR (INOPERABLE) (A68842)
KUBOTA MOTOR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2012 INTERNATIONAL PAYSTAR 5900I (A67714)
2012 INTERNATIONAL...
